Pc Console side build.
Go to solution Solved by Herman Mcpootis,
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
CPU Cooler: Noctua NH-L9i 33.8 CFM CPU Cooler  ($37.99 @ Newegg)
Motherboard: Gigabyte GA-Z170N-Gaming 5 Mini ITX LGA1151 Motherboard  ($149.99 @ SuperBiiz)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  ($69.99 @ Newegg)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($64.99 @ SuperBiiz)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($69.19 @ NCIX US)
Video Card: Asus GeForce GTX 1080 8GB TURBO Video Card  ($592.18 @ Amazon)
Case: Silverstone RVZ02B HTPC Case  ($72.99 @ SuperBiiz)
Power Supply: Silverstone 500W 80+ Gold Certified Fully-Modular SFX Power Supply  ($89.99 @ B&H)
Monitor: Dell S2417DG 23.8" 2560x1440 165Hz Monitor  ($399.99 @ Best Buy)
Keyboard: Corsair Vengeance K65 Compact Mechanical Gaming Keyboard Wired Gaming Keyboard  ($59.99 @ Newegg)
Total: $1936.28
Generated by PCPartPicker 2016-12-26 00:18 EST-0500
$36 over your $1900 budget but you get a 1440p 165hz g-sync monitor to make up for it.
Hello LLT community!
I want to build a computer that follows these requirements:
  • Gaming Pc only. not editing or content creation
  • 1080p 144FPS / 1440p 120FPS
  • Console size build, very portable  <---- this is important. like you can bring it anywhere in a backpack.
  • No SLI / Crossfire
  • Can be overclocked
  • Include peripherals only monitor (any 1080p/1440p at 144hz or bettler) and keyboard (k70 rapidfire). i already own a G502
  • SSD (i'd like the new 960 evo) + 2Tb HDD classic combo.
  • M.2 Support.
  • No bad PSU. (ej. old green cx series of corsair)
  • Good airflow (if possible)
  • Closed AIO coolers( if better than traditional air coolers)
  • I already own a copy of windows 8.1 pro. (i don't like win 10)
  • Dont exceed 1.9k USD. if exceed must be a good reason. and max 2k
  • Only can be bought through amazon and newegg.
I think that's all. Also do you guys think is worth the wait of kaby lake and the z270 chipsets or just plain get skylake.
Any feedback, suggestions is appreciated.
https://linustechtips.com/topic/712154-pc-console-side-build/
If you're just gaming, don't waste money on an M.2 if the case you end up going with can support a 2.5" SATA SSD and a 2TB HDD (2.5" or 3.5"). You won't see any improvements over SATA III.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
https://linustechtips.com/topic/712154-pc-console-side-build/#findComment-9087624
10 minutes ago, wrathoftheturkey said:
Don't wait for Kaby Lake.
oh! Ok!.
5 minutes ago, TheProfessionalAmateurs said:
Looks good but ain't got monitor and keyboard thanks for the suggestion. but wait 600$ for 960 pro 1tb. R U crazy? definitely not gonna pay that. 250 is acceptable and 500 gb. GOOD. 1tb. nope. why if i already mention the 2 tb hdd.
 OK.
https://linustechtips.com/topic/712154-pc-console-side-build/#findComment-9087638
Total: $1936.28
https://linustechtips.com/topic/712154-pc-console-side-build/#findComment-9087688
Just a little bit off budget. hope you like it :D
CPU Cooler: Corsair H75 54.0 CFM Liquid CPU Cooler  ($74.99 @ B&H)
Motherboard: Gigabyte GA-Z170N-WIFI Mini ITX LGA1151 Motherboard  ($134.99 @ Newegg)
Memory: Kingston FURY 16GB (1 x 16GB) DDR4-2133 Memory  ($75.98 @ PCM)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($79.60 @ NCIX US)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($72.99 @ B&H)
Case: Silverstone RVZ01B Mini ITX Desktop Case  ($78.99 @ SuperBiiz)
Monitor: Asus VG248QE 24.0" 1920x1080 144Hz Monitor  ($269.99 @ B&H)
Keyboard: Corsair K70 RAPIDFIRE Wired Gaming Keyboard  ($109.99 @ Jet)
Total: $1908.68
Generated by PCPartPicker 2016-12-26 00:21 EST-0500
"THE RED ARMY"
| INTEL i5 4690K | GIGABYTE Z97X GAMING 3 | XFX R9 390X | CORSAIR VENGEANCE PRO 4x2 8GB 1600Mhz | CORSAIR H80i | XFX XTR 650W | 1TB WESTERN DIGITAL CAVIAR BLUE | ADATA SP600 256GB | LOGITECH G502 | CORSAIR VENGEANCE 1400 | CORSAIR K70 MECHANICAL RED | NZXT S340 |
https://linustechtips.com/topic/712154-pc-console-side-build/#findComment-9087696
Total: $1936.28
@herman mcpootis your always on point.
before i mark you as solve. i want ask  why not 2 or 3 fans video cards. and why not the sf series of corsair instead of that. also 2400 mhz is enough for oc the i7 to 4.6 or 4.8 ? And thanks for the help
Total: $1908.68
Your selection is similar to pootis is a good build. but sorry the feature  g-sync sold me. Thanks for the suggestion.
https://linustechtips.com/topic/712154-pc-console-side-build/#findComment-9087820
I picked the turbo over the zotac amp so that the 1080 wouldn't release the heat into the case and heat up all the other components. And blower fan gpus tend to perform better in itty bitty cases like the one i linked.
I went with the silverstone psu as i wanted to keep to the budget if possible, you can add it in if you think its worth the investment. The ram speed shouldn't impact overclocking performance, if you want fast there's the g.skill ripjaws 3200mhz 16gb ram for $85.
https://linustechtips.com/topic/712154-pc-console-side-build/#findComment-9087907
