Dark rock pro ram clearance
Solved by W-L,
3 minutes ago, sidskofa said:Would I be able to use a dark rock pro 3 on a Z170-a without needing to get low profile ram?
Thanks in advance ^^
Here this should give a good idea of how much space you have, the cooler has a pretty good clearance even for medium/high RAM heatspreaders:
http://www.bequiet.com/volumes/PDM/_products/bk019/bk019_dim_en.pdf
