I have a RX 480 paired with an i5 6600k that should be able to break the 10,000s in firestrikewithout too much difficulty,  however I'm not able to get much more than 8000. When I compare this to other similar PCs with the same hardware I get the same physics score but with a much smaller graphics score. I have a freesync monitor but I disable both freesync and v-sync so I don't think that could be the issue. I even overclocked my gpu and cpu mildly but still no luck. I think the issue is in the gpu but I don't know what would make it run that slow. Any ideas?
https://linustechtips.com/topic/711854-rx-480-low-firestrike-score/
check your drivers and update them if needed.  Use the disk that came with the card btw.
Never use the disk
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
Bios settings put it in "quiet" mode or something? IDK
Welcome to Maryland.
We have crabs.
