Alright dudes and dudettes, I'm designing yet another custom build for a friend of mine. The budget I'm dealing with is sub grand.
I'm focusing on somewhat more gaming performance and want to design an i3 and i5 configurations (2 separate builds). If the i3 is better all-around (full radiator and better GPU) than what I can put together just to have an i5 then that's what I'll go with.
For the i3 configuration I'm looking at:
GPU - MSI GTX GeForce 1060 6GB
CPU - Intel i3 6100
PSU - Corsair SF450 Gold+
Mo.Bo. - ASUS z170-A MoBo
Rad - Corsair H100i v2
Opt.Dr. - LG UH12NS30
HDD - WD 1TB Black
RAM - Cosair Vengeance LPX 16GB (2x8GB)
Case - Fractal Design Define XL R2
It's just under a grand ($940 plus or minus depending on site and sales)
My client isn't an extreme gamer, so I might be able to compromise on GPU and possibly the cooling situation, but even with that said, where can I cut some fat to implement an i5? If it's not worth it, I'm sure she'll be thrilled with This. Any alternatives that are better in cost/performance I'll certainly look into.
Thanks y'all!
Eternity: i7 6700k, nVidia GTX GeForce 1070, 500GB Samsung 850 Evo SSD/2 TB WD Black HDD, Corsair RM850X Gold+, Corsair H115i Extreme, Fractal Design R4, 16GB Cosair Vengeance 2400,  Acer Predator XB271HU
https://linustechtips.com/topic/711732-xmas-build/
CPU - Intel i3 6100
HDD - WD 1TB Black
Thanks y'all!
id definitely recommend not getting a water cooler on an i3 especially if he isnt overclocking but overall a decent build but yeah maybe switch the h100i for a hyper 212 evo or something like that and maybe try get an i5 instead of an i3 :)
https://linustechtips.com/topic/711732-xmas-build/#findComment-9083913
Cannot recommend it at all. What's your exact budget?
https://linustechtips.com/topic/711732-xmas-build/#findComment-9083933
here you go bruh
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($229.99 @ B&H)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.88 @ OutletPC)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($109.17 @ Jet)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  ($69.99 @ Newegg)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($64.99 @ Best Buy)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.78 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card  ($249.99 @ Jet)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.99 @ Newegg)
Total: $940.77
Generated by PCPartPicker 2016-12-25 11:02 EST-0500
"THE RED ARMY"
| INTEL i5 4690K | GIGABYTE Z97X GAMING 3 | XFX R9 390X | CORSAIR VENGEANCE PRO 4x2 8GB 1600Mhz | CORSAIR H80i | XFX XTR 650W | 1TB WESTERN DIGITAL CAVIAR BLUE | ADATA SP600 256GB | LOGITECH G502 | CORSAIR VENGEANCE 1400 | CORSAIR K70 MECHANICAL RED | NZXT S340 |
https://linustechtips.com/topic/711732-xmas-build/#findComment-9083980
