Just now, _PCBEGINNER_ said:
I need help on my build i finish the plan build not sure if it is good you can judge and change items to make it better my budget is $4000
must have:
4k main screen
1440p monitor or 1080p
Triple monitor setup
and here the link to my build
https://pcpartpicker.com/list/chgvD8
https://linustechtips.com/topic/711101-help-on-my-build/#findComment-9077682
7 minutes ago, _PCBEGINNER_ said:
Here is the duel 1080s
https://pcpartpicker.com/list/MMXgr7
Two 1080s probably isn't the best idea considering how multi cards aren't really great atm. I would switcfh it out for a TItan XP.
Computers r fun
https://linustechtips.com/topic/711101-help-on-my-build/#findComment-9077748
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($324.99 @ Newegg)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($96.99 @ Jet)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($7.49 @ OutletPC)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($147.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 32GB (2 x 16GB) DDR4-2400 Memory  ($174.97 @ Jet)
Storage: Samsung 960 Evo 500GB M.2-2280 Solid State Drive  ($249.99 @ B&H)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive  ($306.18 @ Amazon)
Video Card: Asus GeForce GTX 1080 8GB TURBO Video Card (2-Way SLI)  ($592.18 @ Amazon)
Case: NZXT S340 Elite (Black) ATX Mid Tower Case  ($89.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA 1000 G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($134.99 @ B&H)
Monitor: Dell P2715Q 27.0" 3840x2160 60Hz Monitor  ($469.00 @ B&H)
Monitor: Asus VC279H 27.0" 1920x1080 60Hz Monitor  ($179.99 @ Newegg)
Keyboard: Corsair K70 LUX RGB Wired Gaming Keyboard  ($159.99 @ Corsair)
Mouse: Corsair M65 PRO RGB FPS Wired Optical Mouse  ($39.99 @ Best Buy)
Total: $3746.89
Generated by PCPartPicker 2016-12-23 20:36 EST-0500
https://linustechtips.com/topic/711101-help-on-my-build/#findComment-9077777
Is the EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply have enough power to run my rig or not?
Yes, but its not really a good PSU.
Please answer my monitor question. Three 1080/1440 or 4k for gamming?
Computers r fun
https://linustechtips.com/topic/711101-help-on-my-build/#findComment-9077825
My middle monitor is 4k
the other monitors on right and left are 1080 or 1440p
but I don't know which resolution should it be?
can you tell me or not??
https://linustechtips.com/topic/711101-help-on-my-build/#findComment-9077837
IS, or Planning to be? DO you have the display?
Gamming at 4k means more detail, gamming across three displays means wider screen space. the 1080 cannot only power one 4k display. THe resoloution and displays depend entirly on your budget and personal needs/prefrence.
Here is the build:
https://pcpartpicker.com/list/n8ywm8
Computers r fun
https://linustechtips.com/topic/711101-help-on-my-build/#findComment-9077845
Its good, but just one of those?
Computers r fun
https://linustechtips.com/topic/711101-help-on-my-build/#findComment-9077888
