Silent fan suggestions
Go to solution Solved by WoodenMarker,
9 minutes ago, Addicted said:
Enthoo Pro M from Phanteks
You can find SW3's in stock at ncix: http://www.ncixus.com/products/?usaffiliateid=1000031504&sku=134311&promoid=1081
1 hour ago, Addicted said:
have 0 motor/bearing noise
That being said, this is asking for the impossible.
If you're looking for as low noise as possible and willing to compromise on the color, NF-S12A's would probably be you best bet.
I'm looking for some suggestions for fully black or black/grey 120mm/140mm case fans that are as close to completely silent as possible (particularly with regard to bearing/motor noise).
I bought Be Quiet! 140mm Pure Wings 2 PWM fans, and they made a rattling noise from the motor that was irritating from 1 meter away, so I returned them and bought Corsair AF140 Quiet Edition fans, which ended up rattling about 3 times as loud. My CPU cooler included a 135mm SilentWings 3 fan from Be Quiet! and it is 100% silent until I get close enough to nearly chop my ear off. However both Amazon and Newegg are out of stock of the non high speed SilentWings 3 fans. I considered the black Noctua IndustrialPPC fans, but they only come in 2000 and 3000 rpm, and I've heard it is next to impossible to get them truly silent.
My requirements are that the fans, enclosures, mounts, and cables must be fully black or black with dark grey accents (colored stickers are fine), 120mm or 140mm, have 0 motor/bearing noise, and I would prefer to pay $30USD or less per fan (though at this point I may be willing to sacrifice my first-born child).
I know I'm picky, but any suggestions would be greatly appreciated.
https://linustechtips.com/topic/711099-silent-fan-suggestions/
Fractal Design Venturi fans
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/711099-silent-fan-suggestions/#findComment-9077683
Where are you planning to use the fans?
Where are you shopping/located?
https://linustechtips.com/topic/711099-silent-fan-suggestions/#findComment-9077812
I will be using them as front intake and rear exhaust (not mounted on any radiators).
I'm located in the US (Oregon, specifically)
https://linustechtips.com/topic/711099-silent-fan-suggestions/#findComment-9077842
What case?
https://linustechtips.com/topic/711099-silent-fan-suggestions/#findComment-9077847
https://linustechtips.com/topic/711099-silent-fan-suggestions/#findComment-9077883
Oh wow! I guess I didn't look hard enough when I checked NCIX for the SW3. I think I will spring for those. Thank you very much for your help! If I have trouble with those (god forbid), I will try the NF-S12As or the Venturi fans that ivan134 suggested
https://linustechtips.com/topic/711099-silent-fan-suggestions/#findComment-9077926
Venturi's can't get nearly as quiet as SW3's or NF-S12A's.
https://linustechtips.com/topic/711099-silent-fan-suggestions/#findComment-9077943
