It's a good PSU, but can you show us your build?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/710267-650w-power-supply/#findComment-9067972
Its not built yet I am still getting parts but after a power supply I have the CPU cooler and the memory to get but
I5 6600k
Xfx r9 390x
MSI gaming m5 motherboard
G skill ripjaws 5 (2x8)
Phanteks ph-tc12dx_bk
Corsair 120 mm AF 120mm x 3 and 1 sp 120 all led
Samsung 850 evo 500gb and WD blue 1tb
And thinking on the 650 g2 but wasn't exactly sure heard good things about it but same goes for the corsair fans I have and they aren't too great but they get the job done.
https://linustechtips.com/topic/710267-650w-power-supply/#findComment-9067996
I5 6600k
Xfx r9 390x
Can you get yourself the RX 480?
You should be able to get by with a 550W G2, but the 650W would allow you to run two GPU's for SLI.
https://linustechtips.com/topic/710267-650w-power-supply/#findComment-9068009
Already have the 390x and my brother had a 390 and a friend has  480 with the same processor and my brother gets nearly 20 fps more in games at the same settings anyways and the 390x was in sale for 240 on newegg
https://linustechtips.com/topic/710267-650w-power-supply/#findComment-9068031
And no a 650 won't let me crossfire at all last time I did that with a 700w no a crappy CX and my computer fried
https://linustechtips.com/topic/710267-650w-power-supply/#findComment-9068033
Get the 650W. It will allow you to get a 2nd 390x if you find one for less than a better single will give you.
https://linustechtips.com/topic/710267-650w-power-supply/#findComment-9068038
Corsair CX? If it was, it's due to bad design of the PSU itself.
https://linustechtips.com/topic/710267-650w-power-supply/#findComment-9068043
I'd personally not put two cards that use upwards of 300W apiece in a build with a 650W PSU but that's just me.
1 hour ago, Dogsparky said:
Before I pull the trigger is the evga 650w g2 a good power supply? If not what would be better that is around 90 USD?
The 650G2 is probably the best PSU under $100.
https://linustechtips.com/topic/710267-650w-power-supply/#findComment-9068379
Didn't know that thing used that much. Kind of good that the 480 uses less.
https://linustechtips.com/topic/710267-650w-power-supply/#findComment-9068503
Yeah, a Guru3D article with the MSI Gaming edition of it (so mildly overclocked) ran at around 260W http://www.guru3d.com/articles-pages/msi-radeon-r9-390x-gaming-8g-oc-review,8.html
If you were to overclock that about as far as it could go (which you would do if you had two cards, let's be real here) then I'd bump it up.
https://linustechtips.com/topic/710267-650w-power-supply/#findComment-9068564
I don't think that overclocking is advisable with SLI since the cards need to match clocks, but I see your point.
https://linustechtips.com/topic/710267-650w-power-supply/#findComment-9068588
