CPU Cooler. 155mm Max. £30 Max.
Solved by tomas710,
36 minutes ago, somerandomguy12 said:hey guys,
I have a Thermaltake Versa H15 case which has a CPU cooler clearance of 155mm. i have been playing BF1 at ultra setting and my CPU goes up to 70*C on the stock Intel cooler. so I was wondering what would be the best bang for your buck CPU cooler under £30 that will do the job in my case?
Thanks!
Edit: Cryorig is not sold in the UK.
This is as bang for the buck as it gets
https://uk.pcpartpicker.com/product/b8h9TW/raijintek-cpu-cooler-0r100009
