Enough power?
4 hours ago, AinsleyHarriot539 said:
A reference 1070 consumes around 500w and a reference 750ti consumes around 300w. Without knowing the wattage of the psu you wont be able to know.
A 750Ti consumes up to 75W (no PEG) or maybe 100W (OC) , a 1070 is around 150-200W typically. You quoted the PSU requirement from Nvidia. Basically if you use a shit PSU, you'll need a 500W unit to barely power it without causing an inferno.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/709824-enough-power/#findComment-9063656
