Get a different power supply
https://linustechtips.com/topic/709755-final-thoughts/#findComment-9061985
3 minutes ago, OswaldJr said:
So I talked to a few people on the forums and they helped change up the build I was planning to buy and this is the new product https://pcpartpicker.com/list/cBWsVY So I was wondering if you guys have any more advice based on this build idea.
Thanks in advance :D
looks good
https://linustechtips.com/topic/709755-final-thoughts/#findComment-9061990
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($324.99 @ Newegg)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.88 @ OutletPC)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($153.89 @ B&H)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($84.99 @ Newegg)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($69.99 @ SuperBiiz)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($68.15 @ NCIX US)
Video Card: Asus GeForce GTX 1070 8GB Dual Series Video Card  ($404.99 @ B&H)
Case: NZXT S340 (White) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ Jet)
Total: $1288.86
Generated by PCPartPicker 2016-12-20 18:58 EST-0500
https://linustechtips.com/topic/709755-final-thoughts/#findComment-9062021
Total: $1288.86
How about this PSU?
https://linustechtips.com/topic/709755-final-thoughts/#findComment-9062048
10 minutes ago, deXxterlab97 said:
How about this PSU?
Works too, i was picking the 750w for SLI headroom.
https://linustechtips.com/topic/709755-final-thoughts/#findComment-9062101
Total: $1288.86
So basically change the i5 to an i7 then have less SSD and more HDD storage, then change the case and the power supply? Anything else I'm missing, but it looks great to me xD I didn't really know how much SSD space I would need. Also it is okay that the PSU is Semi-Modular right?
https://linustechtips.com/topic/709755-final-thoughts/#findComment-9062156
yup. perfectly fine, its just the required motherboard connector that's fixed to the psu.
https://linustechtips.com/topic/709755-final-thoughts/#findComment-9062265
Total: $1288.86
Yup, this looks good
https://linustechtips.com/topic/709755-final-thoughts/#findComment-9062674
