https://www.kogan.com/au/buy/kogan-24-led-144hz-gaming-freesync-monitor/?utm_source=google&utm_medium=product_listing_ads&gclid=Cj0KEQiAyuPCBRCimuayhb3qqvwBEiQAgz62kQ6Eqyf01eMRvenZ7MTaTxfiJp-ahOh11GvSJSopztIaAl-s8P8HAQ
This monitor does not have the freesync range and am wondering what it is. Also is Low frame rate compensation compatible? I heard it makes low fps like 30-40 feel like 40-50.
This is the cheapest monitor EVER with 144Hz and freesync and its 24" so perfect sizeand is the exact same size as my other one
https://linustechtips.com/topic/709731-freesync-range-lfc/
5 hours ago, Teemo4Life said:
Its 40-144Hz freesync range is that good?
that's pretty solid. the lowest you'll typically see freesync is 30 but you may be able to get the monitor down to that. either way, if you drop below 40hz on a 1080p monitor, you have other problems in your system somewhere.
https://linustechtips.com/topic/709731-freesync-range-lfc/#findComment-9063336
Maybe during intense fights and rare spikes..
https://linustechtips.com/topic/709731-freesync-range-lfc/#findComment-9063343
