So I am struggling trying to find fans for the following build I am hoping to put together soon:
https://pcpartpicker.com/list/M8VzXH
and I need some case fans. I have been looking at Corsair AF fans because of the nice looks on the quiet/high performance models and the LEDs on the regular ones, but I'm not sure I want to commit to anything unless I know they're good. I've heard great things about Noctua fans, but I think the combination of barf tan and poop brown would match the rest of my rig too well, and I want my fans to clash a little with my case and motherboard. /s   But seriously, any advice/suggestions would be appreciated, and any recommendations for changes to the build wouldn't hurt either.
Thanks!
Welcome to Maryland.
We have crabs.
https://linustechtips.com/topic/709598-case-fans/
6 minutes ago, deXxterlab97 said:
8GB 480 and not NEX PSU
A monitor with free sync and 144hz if not too much
No need for 6600k. Get b15-/h110 mobo and go 6500 then you also save money for cooler
Cryorig fans? I mean the included fans with case is enough
6 minutes ago, Electronics Wizardy said:
case comes with fans, your fine
You through think two fans is enough? I will trust your opinion but it seems like at least one more intake could help. Also if I dropped the 6600k and used the money I saved by buying a 6500 on a cooler why would I need a cooler if it's  not unlocked and I won't overclock. Also I have no need for a 8gb 480 given the price difference for performance gains only in extreme situations. I have been looking into a freesync monitor for a while but am still looking.
Thanks!
Edit: I changed the PSU to a 550 G2, I'm pretty sure that's high up on the tier list?
We have crabs.
https://linustechtips.com/topic/709598-case-fans/#findComment-9060304
Thanks!
Do you need to OC at all, What are the need for an unlcoked 6600k? 6500 comes with stock cooler so you don't need to get one, hence I say save money for coooler (maybe I expressed that wrong lol)
https://linustechtips.com/topic/709598-case-fans/#findComment-9060310
Thanks!
Its mor than enough. Modern systems use very little power.
https://linustechtips.com/topic/709598-case-fans/#findComment-9060319
Oh I get it, I thought you meant put the money saved from the 6500 and put it into a better CPU cooler lol.
We have crabs.
https://linustechtips.com/topic/709598-case-fans/#findComment-9060321
