Leaving Workstation running overnight
I have a question about leaving workstations running overnight, and I have not found a clear answer online yet. A few people told me that they are leaving their workstations running overnight once they are done using them. Generally I turn off my workstation once I am done using it. Then I did some research online and opinions seem to be split. There are pros and cons to leaving workstations running all the time, but I cannot find any clear evidence or research on this topic.
So, my ultimate question is... What exactly are the pros and cons of leaving a workstation running overnight and is there any clear research on this topic.
https://linustechtips.com/topic/709224-leaving-workstation-running-overnight/
what are you gonna be doing that it needs to be running overnight?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Pro´s and Con´s are the same like with any other PC. My WS runs for Days if needed. If not i turn it off. Simple.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Well I fold so my computer is usually on 24/7, but besides that my AV runs a full scan on every single file overnight.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
Pros: It's available in the night for Windows 10 to do background stuff like defragmenting, virus scans, indexing, and automatic updates during those periods when you're not using, rather than trying to do that stuff when you are using it because it doesn't have any other choice. If your boot drive is a hard drive you also don't need to wait for it to boot up/resume.
Windows 7 and 8 did have background scheduling for some stuff too, but it was usually less in your face than Windows 10 so it wasn't such a big deal.
Cons: it uses more power when it's on, even when idle, so it does cost money to leave it running, even though not directly.
15 hours ago, SpaceGhostC2C said:
What do you mean by worskstation running overnight? Is it a PC that you consider a workstation doing stuff overnight? Or do you simply mean leaving your computer on at work, just idling, when going home?
By workstation I mean like a simulation workstation, like, 2 xeon cpus, 128gb ram, quadro etc.... Usually it is just idling and very rarely running something overnight.
8 minutes ago, g00gl3 said:
Just leaving it on, leaving applications running and locking windows. Usually not running anything intense.
then theres no point.
Old Rig
There are barely any pros or cons then. You spend electricity while idling, which shouldn't be much, but more than zero. On the other hand, you save starting it up each time you are going to use it.
Other than convenience and the energy bill, I can't think of much else that could matter.
