5 minutes ago, COUPER MILLAR said:
It should be. http://outervision.com/power-supply-calculator I always run my builds through this calculator just to make sure. I'd also take a look at this forum post to determine which ones you would be comfortable with.
Thank you so much :) its help me a lot
https://linustechtips.com/topic/709094-help-me/#findComment-9054543
