Really good build.
You MIGHT want to get a larger HDD if you have a lot of media and what not.
Also 550W is a tad on the small size
CPU: Intel Core i7 8700k CPU Cooler: Corsair Hydro Series H100i Mobo:  Memory: G.Skill Ripjaws X 32GB 2133 Storage #1: 1TB 850 EVO SSD Storage #2: Western Digital Black 2TB Storage #3: Western Digital Green 4TB GPU: Gigabyte 980 Ti G1 Case: Mastercase5 PSU: EVGA 750 W G2 80+Gold Keyboard: Corsair K70 RGB Cherry MX Brown Mouse: Razer Deathadder Elite Monitor: LG 34UM94 Headset: Bose
Phone: Samsung Galaxy S9
https://linustechtips.com/topic/709031-thoughts-on-build/#findComment-9053857
Looks good mate,
All i really have to say is maybe to run the math on the PSU, I'm not sure 550 watt is quite enough, I may be wrong, but i think its a touch low especially if you're looking at maybe adding another gpu at some point. You can use a PSU Calculator and stuff to figure it all out but other than that the build is fine! Good work!
TBH, i dont think you need much more power, i run a 700 watt, and thats heaps for the system i'm running, even when it ran 2 gpus.
New System:        Old System:
Core i7 7700k        Core i5 3550
Gigabyte GA-Z270-Gaming K3        Gigabyte GA-Z77-D3H
Corsair Vengeance LPX 32GB (2x16GB) DDR4                                          GSkill Ripjaws X 8GB (2x4GB) DDR3
Gigabyte GTX1080 Windforce  (8GB)                                                          Gigabyte AMD HD7850 Windforce (2GB)
ThermalTake View27        Antec 1200 V3
SSD: Intel 730 Series - 250 GB        SSD: Intel 730 Series - 250 GB
HDD: WD Green 4TB, Seagate Ironwolf 6tb                                                HDD: WD Green 4TB
EVGA 700B        EVGA 700B
Deepcool Capitain 240EX AIO        Cooler Master X6
Cooler Master MasterKeys Pro L (MX Blue)                                                Razer Arctosa
Corsair Scimitar RGB Black        Razer Naga Hex (Red)
Windows 10        Windows 7, then Windows 10
https://linustechtips.com/topic/709031-thoughts-on-build/#findComment-9053861
the ssd is really small, i would save up for at least 500gb personally. other than that it looks good, psu is a bit on the low side but without too much overclocking its fine. if you realy want to  overclock i would look at 600 watt or 650. if you just want to be set for the future go with 750 thats all you will need with sli and stuff like that, its more than you will ever need.
https://linustechtips.com/topic/709031-thoughts-on-build/#findComment-9053865
Maybe get a bigger SSD, 120 GB is not a lot, especially if you eant some games on it
CPU Intel Core-I5 6600K OC to 4.4GHz MOBO MSI Z170A Gaming Pro Carbon RAM 16GB Kingston HyperX Savage DDR4-2400MHz GPU Gigabyte GTX 1060 G1 Gaming 6GB
Cooler Cooler Master Hyper212 Evo PSU Corsair RM650x 650W Boot drive Kingston v300 120GB SSD Storage WD Blue 1TB 7200rpm HDD Case Corsair Carbide Spec-03
Extra NZXT Hue+ LED light controller + 2xNZXT Aer 120mm RGB fans
https://linustechtips.com/topic/709031-thoughts-on-build/#findComment-9053866
5 minutes ago, KeFy said:
Different cooler if you plan to OC. 212 Evo is not really the best. You spend a lot for this build then let's make cooing better. Dark Rock Pro, Noctua or Cryorig are good
Get a 2 TB drive, cheaper than buying 2 seperate drives
Also 120GB SSD is limited trust me
https://linustechtips.com/topic/709031-thoughts-on-build/#findComment-9053871
11 minutes ago, KeFy said:
looks good
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/709031-thoughts-on-build/#findComment-9053885
3 minutes ago, Thread212 said:
Not bad.
Though SSD could be better.
Like adata XPG series or OCZ trion.. or samsung 850 evo if u have the money.
U may need a larger HDD for storage devices.
550w is plenty enough for single GPU.
and psu calculator is not accurate.
Agreed. 750w is not needed, especially when it is a NEX psu. The original G2 was better
https://linustechtips.com/topic/709031-thoughts-on-build/#findComment-9053886
