I have a great idea, as i think the Define R4 looks like a fridge i thought that it should give out ice, im thinking that in some way it could be modded to give out ice. What opinions do you have on this, im sure it would destroy all of the builds of the week and then Fractal design could enter another market, the pc world and the fridges, amazing.
Listen if you care.
https://linustechtips.com/topic/70903-define-r4-ice-dispenser/
I think it would be amazing! :)
But how would have the space to fit it? There is a limit to the size people want to have they're cases at...
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/70903-define-r4-ice-dispenser/#findComment-971655
Step 1: Shut down PC.
Step 2: Sleep, it sounds like you need it.
Step 3: Continue your day.
Computer Specs: CPU: i7 3770k, GPU: EVGA GTX 770, PSU: Corsair HX 850W, Case: Fractal Design R4, Motherboard: MSI Z77A-GD65, RAM: Corsair Vengeance 16GB 240 Pin DDR3, Corsair H100i Liquid CPU CoolerKingston HyperX 240GB SSD (OS), WD 1TB HDD Black Edition
https://linustechtips.com/topic/70903-define-r4-ice-dispenser/#findComment-971657
Go for it, if you can mod a freezer into it it would be pretty cool.
Pun intended.
https://linustechtips.com/topic/70903-define-r4-ice-dispenser/#findComment-971659
