22 minutes ago, BlackLivesMatter said:
Well someone said to me it was a really good one. Is there anything else you could recommend? Samsung 850 evo?
You want cheap or expensive?
If you want a budget reliable SSD, the SanDisk 480gb G26 is a good call, what you do with it matters most when you want it to last, for instance it is advised to always have a HDD installed along side so you can transfer Virtual Memory, tmp files, temp files and other stuff so that will decrease the writing amount on the SSD increasing its life span.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/708989-ssd-help/#findComment-9053782
