Is my CPU temperature accurate?
You need to go into AIDA64 preferences and enable Package Temps. Pay more attention to Package Temps than core temps on a Broadwell-E CPU.
Also, when you run AIDA64 for CPU stability, only run CPU, FPU and cache checked otherwise your temps will be a little lower when you run all tests like you did.
Other than that, your temps are average for your overclock. Nothing to worry about.
As an example of why you should monitor Package Temps, look at the screen shot I've provided. You'll see all of the core temps in the 50's, but package temps (Purple Line) are much higher. Haswell-E and Broadwell-E package temps get quite a bit higher than core temps. This is only to show you the difference in Package and core temps, not for comparing temps as we have different hardware and overclocks.
