Psu- thermaltake 730w smart
Motherboard - gigabyte ga-b85-hd3
Cpu - i5 6500
Gpu - x2 r9 280x
Hdd- 1x 500gb toshiba 1x 1tb toshiba 1x 4tb seagate
Ssd- 1x sandisk 120gb
Ram - 2x crucial 4gb ddr3 1x hyperx 8gb ddr3
The system started to act wierd a couple of weeks ago , shut downs  loop restarts , blue screens .
Yesterday i had a couple of blue screena saying bad memmory , and then a beep code says the memmory sticks are failing, so i tried them on my test bench and they worked perfectly  .
And now im havin hard time booting up from my ssd
Something is very wrong with my pc .
What should i do?
Any suggestions?
https://linustechtips.com/topic/708612-whole-system-acts-wierd/
Cpu - i5 6500
Gpu - x2 r9 280x
What should i do?
Any suggestions?
Maybe because you are running different sticks or RAM at once. Try this with only the 8gb stick or the 4gb sticks
Hello
https://linustechtips.com/topic/708612-whole-system-acts-wierd/#findComment-9049409
4 hours ago, TAHIRMIA said:
Try to boot without your GPU
Next time quote me so I get the notification
Seems like it was the windows itself that was broken ? reinstalled windows , ran some bench marks looks stable so far il keep an eye for a couple of days and il let you know
https://linustechtips.com/topic/708612-whole-system-acts-wierd/#findComment-9050717
Cool mark it solved
Hello
https://linustechtips.com/topic/708612-whole-system-acts-wierd/#findComment-9050771
