19 minutes ago, Petikeki said:
I just bought my new gaming pc and my question is what needs a driver update (I know that the GPU needs one).
Does the MOBO needs a driver update?
Could anyone list me the links where I can find the drivers?
GPU:XFX RX 480
MOBO:Asrock B150M ProV4
THX
Follow the guide in my signature.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/708448-driver-help/#findComment-9047950
