1 minute ago, echy said:
what about ram?
Probably not. If you're getting a Skylake system, then you need DDR4, so it definitely won't be compatible. If you're getting a Haswell system, then you need DDR3 and if your "super old" pc is older than 2010, then it's probably DDR2.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/708325-optical-drive/#findComment-9046571
4 minutes ago, echy said:
ram isnt universally compatible ? its not server ram just like an old desk top that i want to put to an new desktop. do you think it will be compatible or depends
No. There are different revisions of RAM. DDR was common until 2006~, DDR2 until 2009~, DDR3 until 2015~, and DDR4 today.
PSU Tier List | CoC
https://linustechtips.com/topic/708325-optical-drive/#findComment-9046579
