Alright, while watching some old minecraft videos with gtx 970s, I notice that they are getting better frame rates and higher setting in minecraft shaders than my gtx 1070.
My problem is I'm running the game at standard settings but I average around 120 fps and 12 chunks rendered. I turn the render distance up to 16 chunks and I drop down to 80 fps at 1080p.
With a sorta high end system like mine I would expect to have most of these settings cranked to the max but I can't. Yet someone with a gtx 970 and i7 4790k gets way better fps. I don't know if anyone else has this issue or it's just me or minecraft mods run like crap. I am running Sildurs vibrant shaders extreme and vatics faithful texture pack.
PC specs:
Core i5 6600k oced to 4.2 Ghz
MSI GTX 1070 armor oc edition
16gb of Corsair vengeance lpx ddr4 ram @ 2666 Mhz
Asus Z170-A motherboard
Cooler master hyper d92
250gb Samsung 940 evo ssd
1tb WD blue hard drive
EVGA supernova 550W g2 power supply
"Friendship is two pals munching on a well-cooked face together"
https://linustechtips.com/topic/707875-low-fps/
3 minutes ago, elpiop said:
How much ram do you have allocated to the game? If you're just using the default amount you're probably going to want to bump it up quite a bit when using shaders and hi res texture packs.
I allocated 10gb.
https://linustechtips.com/topic/707875-low-fps/#findComment-9042261
PC specs:
Drivers.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/707875-low-fps/#findComment-9042272
If you're getting lag spikes I would recommend lowering the RAM allocation to like 4gb. When the jvm does garbage collection it can cause your framerate to spike if using the default GC. If you do want to keep the value high then I think you can put this in your launch options:  -XX:+UseG1GC . The game will then use a garbage collector that is designed to support heaps > 4gb.
If you aren't getting lag spikes then don't worry what I've just said, there is something else impacting performance.
https://linustechtips.com/topic/707875-low-fps/#findComment-9042287
It's probably that Minecraft mods run like crap.  As much as mods are great, a lot of them are written sloppily. xD
Sorry for the mess!  My laptop just went ROG!
"THE ROGUE":  ASUS ROG Zephyrus G15 GA503QR (2021)
  • Ryzen 9 5900HS
  • RTX 3070 Laptop GPU (80W)
  • 24GB DDR4-3200 (8+16)
  • 2TB SK Hynix NVMe (boot) + 2TB Crucial P2 NVMe (games)
  • 90Wh battery + 200W power brick
  • 15.6" 1440p 165Hz IPS Pantone display
  • Logitech G603 mouse + Logitech G733 headset
"Hex": Dell G7 7588 (2018)
  • i7-8750H
  • GTX 1060 Max-Q
  • 16GB DDR4-2666
  • 1TB SK Hynix NVMe (boot) + 2TB Crucial MX500 SATA (games)
  • 56Wh battery + 180W power brick
  • 15.6" 1080p 60Hz IPS display
  • Corsair Harpoon Wireless mouse + Corsair HS70 headset
"Mishiimin": Apple iMac 5K 27" (2017)
  • i7-7700K
  • Radeon Pro 580 8GB (basically a desktop R9 390)
  • 16GB DDR4-2400
  • 2TB SSHD
  • 400W power supply (I think?)
  • 27" 5K 75Hz Retina display
  • Logitech G213 keyboard + Logitech G203 Prodigy mouse
Other tech: Apple iPhone 14 Pro Max 256GB in White, Sennheiser PXC 550-II, Razer Hammerhead earbuds, JBL Tune Flex earbuds, OontZ Angle 3 Ultra, Raspberry Pi 400, Logitech M510 mouse, Redragon S113 keyboard & mouse, Cherry MX Silent Red keyboard, Cooler Master Devastator II keyboard (not in use), Sennheiser HD4.40BT (not in use)
Retired tech: Apple iPhone XR 256GB in Product(RED), Apple iPhone SE 64GB in Space Grey (2016), iPod Nano 7th Gen in Product(RED), Logitech G533 headset, Logitech G930 headset, Apple AirPods Gen 2 and Gen 3
Trash bin (do not buy): Logitech G935 headset, Logitech G933 headset, Cooler Master Devastator II mouse, Razer Atheris mouse, Chinese off-brand earbuds, anything made by Skullcandy
https://linustechtips.com/topic/707875-low-fps/#findComment-9042298
I honestly don't get it. I don't know if it's minecraft or my pc. I have fallout 4 using the recommended settings in GeForce experience and it runs just fine. Guild wars 2 with its outdated API runs fine 60 fps with max settings. I feel like it's a hit-and-miss with minecraft.
https://linustechtips.com/topic/707875-low-fps/#findComment-9042330
I don't have many lag spikes, only when I turn the chunks up to 16 the fps goes down very slowly.
https://linustechtips.com/topic/707875-low-fps/#findComment-9042351
