1 minute ago, GM Rod said:
They're DSLRs, so HDMI, yes.
I need to get to bed, but check out some of the capture cards at http://www.magewell.com/
I noticed some ones in there that may be able to capture 2 or 4 4k hdmi on a single pci.
If you can slim down your capture card, then I would go with https://pcpartpicker.com/list/NzfjRG
I don't see a point in dual Titan X. That would be like $3800. It would probably be better to just add a third GTX 1080 instead (if you find a small enough capture card).
14 hours ago, GM Rod said:
Ok so this is what I've reached. Minus $1600 if I get the used CPUs.
https://pcpartpicker.com/list/V98vD8
Looks good to me. If you are going to be monitoring four HDMI inputs at once, you may want to invest in another monitor or two. Besides that, assuming you looked into the capture card are it is what you want, I say you go for it.
