BSOD when using qbittorrent
Go to solution Solved by rattacko123,
Instead of making this thread, I should have installed older driver first, but anyway... Problem Solved!
I updated my motherboard BIOS, even reseated my graphics card to make sure, and installed the older driver for the wifi card (non region locked driver with included software) now I can change settings on my wifi card, and besides some issues that were solved by a simple restart, I can "download" again :D
Whenever I open qbittorrent I get a BSOD, sometime it happens immediately, sometimes after a few minutes. This behaviour only started yesterday and I could use some help!
following this tutorial:
The google drive link is down below (also with the standalone dump files if you need them) although for some reason perfmon didn't work (still doing its thing for 10 minutes)
https://drive.google.com/drive/folders/0BxNf_qKrgqsjU1p4em43R3ZFZnc?usp=sharing
System specs
·OS - Windows 10 64-bit
I installed windows 10 fresh install (only 2 weeks old)
My computer is around 2 years old, some components (such as motherboard, cpu and ram) are 1 month old
· CPU - Intel Xeon E3 1230 V5
· Video Card -  Gigabyte g1 gaming GTX 970
· MotherBoard -  MSI Xeon E3 Krait Gaming V5 Workstation
· Power Supply - evga g2 1000w
sound card - Xonar U7
wifi card - ASUS PCE-AC68
hello!
is it me you're looking for?
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
Cooler: Dark Rock Pro 3
RAM: 32GB DDR4
GPU: GTX 1080
Storage: 1TB 850 Evo, 1TB HDD, bunch of external hard drives
PSU: EVGA G2 750w
Peripherals: Logitech G502, Ducky One 711
Audio: Xonar U7, O2 amplifier (RIP), HD6XX
Monitors: 4k 24" Dell monitor, 1080p 24" Asus monitor
Laptop:
-Overkill Dell XPS
Fully maxed out early 2017 Dell XPS 15, GTX 1050 4GB, 7700HQ, 1TB nvme SSD, 32GB RAM, 4k display. 97Whr battery :x
Dell was having a $600 off sale for the fully specced out model, so I decided to get it :P
-Crapbook
Fully specced out early 2013 Macbook "pro" with gt 650m and constant 105c temperature on the CPU (GPU is 80-90C) when doing anything intensive...
A 2013 laptop with a regular sized battery still has better battery life than a 2017 laptop with a massive battery! I think this is a testament to apple's ability at making laptops, or maybe how little CPU technology has improved even 4+ years later (at least, until the recent introduction of 15W 4 core CPUs). Anyway, I'm never going to get a 35W CPU laptop again unless battery technology becomes ~5x better than as it is in 2018.
Apple knows how to make proper consumer-grade laptops (they don't know how to make pro laptops though). I guess this mostly software power efficiency related, but getting a mac makes perfect sense if you want a portable/powerful laptop that can do anything you want it to with great battery life.
https://linustechtips.com/topic/707424-bsod-when-using-qbittorrent/
System specs
My first question is what does event viewer say?  I've had this issue before and I think it was due to the wireless card (I have the ASUS PCE-AC68 as well)...
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
How do I check even viewer? all it says system shut down unexpectedly, and a computer has reported from a bug check. How do I check the dumps themselves?
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
I didn't suggest any of the dumps.  Go to event viewer and look at what events are happening.  (PS error 41 is a generic error, do not report back regarding error 41, dig deeper)
there are like 4500 events, I can't look through all of them, how do I find BSOD events specifically?
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
Well, the best way to do it is realize the time and date that you had the BSOD and then look at everything around that time.  That should narrow it down quite a bit.
oh wait, I found something
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="Microsoft-Windows-Kernel-EventTracing" Guid="{B675EC37-BDB6-4648-BC92-F3FDC74D3CA2}" />
  <EventID>3</EventID>
  <Version>1</Version>
  <Level>2</Level>
  <Task>2</Task>
  <Opcode>14</Opcode>
  <Keywords>0x8000000000000010</Keywords>
  <TimeCreated SystemTime="2016-12-06T10:25:22.954589200Z" />
  <EventRecordID>9</EventRecordID>
  <Correlation />
  <Execution ProcessID="4" ThreadID="148" />
  <Channel>Microsoft-Windows-Kernel-EventTracing/Admin</Channel>
  <Computer>DESKTOP-LITF6U0</Computer>
  <Security UserID="S-1-5-18" />
  </System>
- <EventData>
  <Data Name="SessionName">EventLog-AirSpaceChannel</Data>
  <Data Name="FileName">C:\Windows\System32\Winevt\Logs\AirSpaceChannel.etl</Data>
  <Data Name="ErrorCode">3221225864</Data>
  <Data Name="LoggingMode">8388737</Data>
  <Data Name="FailureReason">0</Data>
  </EventData>
  </Event>
airspacechannel appears to be something related to wifi card
the most recent one is BootCKCL, but nothing around the time of the BSOD
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
- <System>
  <Level>2</Level>
  <Task>2</Task>
  <Opcode>14</Opcode>
  <Correlation />
  </System>
- <EventData>
  </EventData>
  </Event>
That error code tells us nothing important.
found it I think
Failed to connect to the driver: (-2147024894) The system cannot find the file specified.
^^is that the right one?
Oh wait nvm that one is dropbox
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
2 minutes ago, rattacko123 said:
found it I think
You should be looking (typically) in "Application", "Security", and "System" as a rule of thumb.  Anything else probably isn't going to be very helpful.
You're more than welcome to send them to me and I can look and see what I find.
OK I think I may have found it error
Microsoft-Windows-DistributedCOM
https://answers.microsoft.com/en-us/windows/forum/windows_7-performance/error-microsoft-windows-distributedcom-id10010/481acdc3-3402-40ac-af9a-330908fd5754
appears to be wifi driver, also says an app didn't start or something
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
5 minutes ago, rattacko123 said:
found it I think
ok it appears the BSOD happened at 12:34, gonna check that specific timeframe
Anything specific I need to look for? like what kind of error, and how do identify what is causing the error?
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
Well, if I knew what kind of error to look for I'd be able to tell you what the problem is...  That's why we look at Event Viewer.
Ok, so how do I send them to you? via message or?...
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
Like if you're wanting me to look at it?  However you feel like.  I wouldn't just post them to the thread though.
Ok, I have sent you a message, there are 2 errors that I have found when looking through  "Application", "Security", and "System"
appears like wifi problem, now what method should I use to fix?
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
Both the errors you reported to me seemed to be fairly unimportant errors that should not cause any kind of blue screen.
I'll try replicating the BSOD to see if I can get any useful errors out of it, I also need to check the error code as I forgot to mention that in the OP (I think it was something related to drivers, but idk). Meanwhile could you send me a link or something of how to fix if it's a wifi card issue?  Sorry if I am asking too much, thanks for your help!
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
I replicated the BSOD and the error is page fault in nonpaged area, sounds like a driver fault (most likely wifi driver) but I'll try reseting my page file to see if that works, will send you a message if I find any new errors
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
Page Fault in Non Paged Area is 99% a driver issue or 1% memory issue.
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
nvm problem is solved, thank you so much for your help! damn this event viewer stuff is a pain, and you have helped me to know where to look for these events, etc.
thanks!
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
