Hi.
I'm upgrading my current PC to the following specifications;
PCPartPicker part list: https://pcpartpicker.com/list/qL84Z8
Price breakdown by merchant: https://pcpartpicker.com/list/qL84Z8/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (Purchased For $0.00) -  received as a gift
CPU Cooler: Corsair H50 57.0 CFM Liquid CPU Cooler  (Purchased For $0.00) - received as a gift
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  (Purchased For $0.00) - received as a gift
Memory: G.Skill NS Series 8GB (2 x 4GB) DDR3-1333 Memory  (Purchased For $0.00) - already own
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (Purchased For $0.00) - already own
Video Card: XFX Radeon RX 480 4GB RS Video Card  ($214.98 @ Newegg)
Case: Corsair 100R ATX Mid Tower Case  ($49.99 @ B&H)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  (Purchased For $0.00) - already own
Total: $264.97
Generated by PCPartPicker 2016-12-15 15:35 EST-0500
What, if any, changes, would you make to my upgrades? I intend on overclocking my 4690K; should I get a higher watt power supply? Also, is it worth replacing my 2 8GB sticks of RAM with ones with heatsinks, or should I just purchase a 16GB set instead? Would you recommend a different GPU? I will be operating on a single monitor at 1080p.
Thank you, any advice is appreciated. Have a great day and enjoy the holidays!
H A L C Y O N
Specs:
CPU: Intel Core i5-4690K @ 3.5GHz
GPU: MSI RX 480 Gaming X 8GB
RAM: G.Skill Ripjaws X 16GB (2x8GB) DDR3-2400
HDD: Seagate Barracuda 1TB 7200RPM
Power Supply: SeaSonic G-Series 550W
Case: NZXT S340 (black/blue)
Peripherals:
Monitor: BenQ RL2455HM
Keyboard: Logitech G810 Orion Spectrum
Mouse: Logitech G502 Proteus Spectrum
Headset: Logitech G633 Artemis Spectrum
Mousepad: HyperX Fury S XL
https://linustechtips.com/topic/707261-its-upgrade-season-help/
I would just add 16GB of RAM as the rest of the system is fine.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034743
You may be at the upper limit of the PSU depending if you want to overclock cpu/gpu. 430W is a bit low for a pretty solid build otherwise
CPU: Intel Core i7 8700k CPU Cooler: Corsair Hydro Series H100i Mobo:  Memory: G.Skill Ripjaws X 32GB 2133 Storage #1: 1TB 850 EVO SSD Storage #2: Western Digital Black 2TB Storage #3: Western Digital Green 4TB GPU: Gigabyte 980 Ti G1 Case: Mastercase5 PSU: EVGA 750 W G2 80+Gold Keyboard: Corsair K70 RGB Cherry MX Brown Mouse: Razer Deathadder Elite Monitor: LG 34UM94 Headset: Bose
Phone: Samsung Galaxy S9
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034757
I second that.
But I would also recommend you consider upgrading your power supply.  AMD's minimum PSU wattage for use with a RX480 is 500W, recommended is 550W.
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034766
How much would you recommend I go up to? 500W, 600W, or more than that?
H A L C Y O N
Specs:
Peripherals:
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034769
600W would be perfect for your system.  500W would be a little on the low end but would still be OK.  Higher than 600W would be overkill.
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034783
I would also opt for the 8gb 480
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034798
If you're on a budget, get something like Corsair's new CX---M series. Great power supplies, unlike the old CX power supplies. The CX550M would be good. If you want premium with Gold efficiency, I'd get the EVGA 550G2, 550GS, or 550GQ. All good power supplies.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034820
if your budget allows:
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2133 Memory  ($79.99 @ Jet)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($81.63 @ NCIX US)
Video Card: Gigabyte Radeon RX 480 8GB G1 Gaming Video Card  ($239.99 @ SuperBiiz)
Case: NZXT S340 (White) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ NCIX US)
Total: $543.59
Generated by PCPartPicker 2016-12-15 15:57 EST-0500
Ryzen Ram Guide
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034830
I'm looking at a budget of anywhere between $250-$350 for everything (GPU, case, additional stuff)
H A L C Y O N
Specs:
Peripherals:
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034836
And to answer your other question: Unless you're overclocking your RAM (which I don't recommend - I don't think it's worth it), heatsinks on RAM don't do much of anything other than make it look nice.
If the most you ever plan to go up to is 16GB of RAM, then just get an additional 2-4GB sticks of what you have.
If you want to be able to upgrade to 32GB in the future, replace the 2-4GB sticks you have now with 2-8GB sticks.
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034841
I will most likely have a maximum of $350 to spend.
I should prioritize the PSU over the RAM obviously. Which PSU should I pick? 550W seems like it is the perfect "sweet spot" at the price point as 500W is still on the low side and anything above 600W is overkill.
Which PSU would you recommend? I'd like a modular one, but it's fine if it isn't.
H A L C Y O N
Specs:
Peripherals:
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034870
Here's the list after adding a new PSU (which I would recommend for that GPU anyways)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.99 @ Newegg)
Total: $329.96
Generated by PCPartPicker 2016-12-15 16:04 EST-0500
Below $350. If you could stretch it, I'd add an SSD, like everybody else is recommending. You don't have to now, it would definitely put you over budget, but it'll make your system snappier.
The PSU itself is this one:
https://pcpartpicker.com/product/3hkwrH/corsair-power-supply-cp9020102na
The Laptop:
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034875
Total: $329.96
I love the choice of parts; it's the best price/performance PSU option I've seen yet.
Would you recommend a different GPU around the same price?
H A L C Y O N
Specs:
Peripherals:
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034897
I agree with that choice of PSU (Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply).  I haven't really come across any at a lower price that I would trust.
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034924
I don't know about the same price. XFX makes great cards, and for the 4GB I'd recommend the one you picked. But, again stretching your budget here, I'd recommend upgrading that 480 to an 8GB one, but it'll be pricey (like, $250 pricey.)
The cheapest one I'd recommend is this one: https://pcpartpicker.com/product/BZJkcf/powercolor-radeon-rx-480-8gb-red-devil-video-card-axrx-480-8gbd5-3dhoc
Cheaper ones are the MSI Armor and Gigabyte G1 Gaming, but both of those have inadequate cooling, making the fans ramp up to keep it cool. More expensive ones will be "better," but you won't be guaranteed to get good overclocks or anything.
The Laptop:
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034936
if you have a efficient power supply you don't need 500w for  a system like yours, rx 480 150w+ oced 4690k 110ish thats your main power usage right there add 100w more for the other stuff and you get to 360ish still well in the psu´s range, thou if you want to buy a new one focus on efficiency and not in power rating 450-550w is the sweet spot because normally at 60-80% usage is were the psus are most efficient.
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034976
Also, 16GB of RAM is NOT necessary, correct?
H A L C Y O N
Specs:
Peripherals:
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9034986
Also (I may as well throw this in here) is there any better case selections for around $50 (feel free to go over maybe $5-$10, I'm buying my GPU in person so I won't have to pay shipping on that)? I need an ATX mid-tower.
H A L C Y O N
Specs:
Peripherals:
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9035013
No, it's not.  If you want to put the money toward some other part of the computer, that would be fine.  You can always add more RAM at a later date when you feel it's necessary.
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9035018
Thank you everyone for all of your help, I really appreciate it.
Is there a better case option for $50-$60? Note that my color scheme will be blue, so any colored cases or lights should go with it. Otherwise, a neutral black would be my preferred color.
H A L C Y O N
Specs:
Peripherals:
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9035044
This is $69 (I know, I'm pushing it), but you might like it: http://a.co/6lErLqt
I haven't used it personally but it's rated well and I've been eyeing it myself.
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9035084
I really like that one. Since I'm buying my GPU in person (adding $5 to the amount I can spend) plus the Xbox I'm trading in (an extra $40) I may have enough cash to get that case. Thank you for the recommendation.
H A L C Y O N
Specs:
Peripherals:
https://linustechtips.com/topic/707261-its-upgrade-season-help/#findComment-9035925
