i just realized the motherboard i am looking to purchase dont come with wifi, the asus z170-a and the msi z170 sli plus, anyone else knows of a motherboard in these price range that comes with wifi, and also anyone know of a good adapter that would work with those motherboards. thank you.
https://linustechtips.com/topic/707154-need-wifi-for-desktop/
You can buy a PCI-E WiFi card for like 拢12. That would be fine unless you're running SLI.
I had an account called Joegeddon active since April 20th 2015
Desktop
AMD Ryzen 5 2600 | XFX RADEON RX580 8GB XXX | 16GB 3000MHz DDR4 | Thermaltake Versa H22 | Corsair RM550x PSU | MSI AM4 B450M-A PRO Motherboard
1TB 7200RPM HDD | 500GB 7200RPM HDD | 500GB M.2 WD BLUE SSD
Laptop - Asus UX303UA
Intel i7 6500U | Intel 530 Graphics | 12GB 1600MHz DDR3 | 256GB SATA 3 SSD
https://linustechtips.com/topic/707154-need-wifi-for-desktop/#findComment-9033340
Just get a simple USB based solution, unless you need something more powerful. Are you going to be streaming, playing online games or the like?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT聽(1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/707154-need-wifi-for-desktop/#findComment-9033403
yes i will be playing online competitive games, i will look forward to plug myself by wire at some point but for now unless i run a giant cable around the house it wont be possible, unless you guys have an idea for that as well.
https://linustechtips.com/topic/707154-need-wifi-for-desktop/#findComment-9033407
2 minutes ago, Howitz said:
yes i will be playing online competitive games.
If so, just get the PCI-E card that the above user linked to. It looks like it would work well for you.聽
Main System: Phobos
https://linustechtips.com/topic/707154-need-wifi-for-desktop/#findComment-9033418
around the outside of the house, or get creative with the baseboards. If you cant fish the line inside the walls, best just to go straight through them and cover them with baseboards.聽
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System聽specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe聽+ 2TB SU800 - EVGA GTX1080ti -聽LianLi PC11 Dynamic
https://linustechtips.com/topic/707154-need-wifi-for-desktop/#findComment-9033496
37 minutes ago, Howitz said:
聽i will look forward to plug myself by wire at some point but for now unless i run a giant cable around the house it wont be possible, unless you guys have an idea for that as well.
I went wired earlier this year and it is well worth it, the full ~1 Gigabit is so much nicer than being capped at ~350聽Megabits (had a dual-band ac router)
https://linustechtips.com/topic/707154-need-wifi-for-desktop/#findComment-9033596
Asus has some cheap option for $20-30 in either USB or PCI-e but if you are wanting to game or download tons of stuff you might want to drop some money on their higher bandwidth ones which are more in the $100+ range.
https://linustechtips.com/topic/707154-need-wifi-for-desktop/#findComment-9034312
