Hey guys, so I'm getting tearing with gsync on and vsync off I'm capped at 142 hz in overwatch and 60 in skyrim.
there is visable tearing
if I turn vsync on in the controll panle it goes away
but does this introduce lagg ??
and why is gsync not working propoerly
iv read on a lot of sights u need v and g sync on in the controll panel and off in game
mid that right ?
Gsync is defiantly on because it's on in controll panel and in my monitor menu it's on and if I turn it completely off the tearing is conciderably worse
just wondering if someone could tell what's going on with nvdia and gsync
it used to be that 30 to 144hz was gsync, with vsync off U could go over and gsync would take over worying thoes peramiters
and v on it would stop at 144hz
but now I have no clue what's going on because I get tearing in between 30 and 144hz
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/706815-gsync-vsync-help-%E2%82%AC/
Vsync in controllpanel = off.
Make sure Gsync is enabled in the controll panel and the monitor itself.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Gsync is always working here regardless of what the Vsync option is...both in games and control panel doesn't matter Gsync is working all the time no tearing what so ever.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
8 hours ago, exyia said:
in nvidia control panel, turn FastSync on
and leave any and all in-game v-sync settings to off
No fast sync with sli
also (1600)
Iv tried all of the above
I still get slight tearing with vsync off tho
also (1600)
Iv done this and still tearing at the bottom of the screen
also (1600)
Ok but why am I getting tearing with it on ?
also (1600)
Sure its tearing? Can you post a picture of it? Gsync eliminates tearing to 100%.
I can't because it's too fast but I can see it for sure
apparently the new driver U have to have vsync on aswell because there trying something new with the fast sync and gsync that's not working right yet even tho fast sync isn't an option
also (1600)
 Forget fast sync. Turn everything but Gsync off. You dont need any of that.
Tried that still tearing :(
anything to do with me installing nvdia inspector ?
also (1600)
Dont know. Try without it. Did the Monitor (Gsync) worked before?
Since the last 2 nvdia drivers but got inspector around the same time but I set it all back to default
also (1600)
You're tearing because you're exceeding your monitor's refresh rate. With G-Sync enabled, leave V-Sync in the control panel enabled. That means V-Sync will only turn on when the refresh rate is exceeded.
As for input lag, it will be marginally increased. If you don't like it, live with the tearing.
My monitor is 144hz and I get tearing at 60 fps and capped at 142 fps
I'm not stupid
also (1600)
Maybe just try older drivers? I've had such shit luck with any sort of recent nvidia drivers
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
Il give it a try,
ur cpu running at 1.39 v is it safe as long as temps are ok ?
also (1600)
Just now, jjohnthedon1 said:
Il give it a try,
I hope so ;) haha I haven't had any issues yet but it's only been 6 months or so at that speed. I figure by the time it shows problems it'll be getting old anyhow.
Gaming temps are in the 50's and stress tests around 70°c.
Same temps as me with a h110
also (1600)
I'm not stupid
I didn't say you were stupid. You may want to adjust your tone, given you're the one asking for help, no?
If you're tearing below that, then G-SYNC isn't active. You can verify this by enabling the G-SYNC indicator in the control panel.
Gsync shows as active,
but there is tearing
also (1600)
33 minutes ago, OnfireYH said:
gsync only works in a specific refresh rate range and only on specific connections. Check your monitors manual.
It's within the peramiters and only connection option is displayport which I use
also (1600)
