Does anyone actually use the fan connectors on the Corsair H100i/H110i or is it common practice to use the MB headers instead?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/706683-use-aio-fan-headers-or-mb/
I use the cpu fan header for mine but it's controlled in the bios even though I have the link software. I have the v2 btw
Main PC:
CPU: Ryzen 5 3600  | GPU: RTX 2060 | PSU:  | Memory: Corsair Vengeance RGB 3200Mhz 16GB | OS Drive: Western Digital Black NVMe 250GB | Game Drive(s): Samsung 970 Evo 500GB | Motherboard:  | Case: Fractal Design Define R6 | Monitor(s):  | Keyboard:  | Mouse: Steelseries Sensei 310
NASUS (NAS)
CPU: Intel Xeon X3440 | Motherboard: Super Micro X8SIL | Memory: 16GB DDR3 1066Mhz ECC UDIMM | HBA: Dell Perc H200 (Flashed to IT Mode) | Drives: 3x 16TB Seagate Exos x16, 2x 6TB Seagate Enterprise, 1x 6TB WD RED
RENEKTON (NAS)
CPU: Intel Core i5 4570TE | Case: Fractal Design Define S | Memory: 16G DDR3 1333Mhz SODIMM | HBA: LSI 1068E (Flashed to IT Mode) | Storage: 4x 3TB Hitachi, 2x 3TB WD RED
I suppose that's another question. The Corsair Link software is terrible for controlling the fan speeds. sudden jumps in speed whereas the software that came with the board allows for ramp up/down so that fan speeds aren't jumping all over the place so rapidly. Does anyone bother to use it? rear and top fans are plugged into the board and they are great, but the H110i fans are using the split from the water block and are just plain annoying as hell.
System specs:
