2 minutes ago, Mastafu said:
Try using a different monitoring software like hwmonitor and see if you still get the same results... looks like a bug in the software
i use corsair link and it shows the same thing. i have also tested other temp monitroing softwares and they show the same thing :( sorry for bad spelling im swedish
https://linustechtips.com/topic/706064-my-temps/#findComment-9020735
That is a faulty sensor. Ignore it.
Moved to Air Cooling.
https://linustechtips.com/topic/706064-my-temps/#findComment-9020748
