How salty is salt water?
QuantumBit
How salty is salt water? I.e If I make a 100% salt water solution (Where salt wont dissolve anymore)  is it as salty as ocean water?
Thanks!
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
Thanks!
100% salt water is just salt at that point. Actually it'll be brine
The scientists have defined how "salty" water is by what percent mass the solution is in salt:
  • Fresh water: <0.05%
  • Brackish water: 0.05% - 3%
  • Saline water: 3%-5% (the lower end is considered sea water)
  • Brine: >5%
Edited by M.Yurizaki
More clarifications, yay!
Thanks!
A saturation solution of water+salt is going to be a lot saltier than ocean water.  The Dead Sea is saltier than ocean water.  Seawater has on average 3.5% salinity, the dead sea is 34%.
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
Thanks
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
One question, if the dead sea is around 33.7% salty, does that mean a solution that can't dissolve any more salt is 100%?
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
  • Brackish water: 0.05% - 3.5%
  • Saline water: 3%-5% (this is considered sea water)
  • Brine: >5%
Can you explain a bit more? If I have a solution that can't dissolve any more salt would it be 50%?
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
Saturation does not mean that it takes 1 unit of volume/mass of the first element to dissolve into another 1 unit of volume/mass of the second element.  It just means the point when something will no longer easily dissolve into something else.  So yes, saturation would be 100%, for the given elements that are being mixed together.
Still not as much as my teammates...
% is the amount of salt inside the water. 99% means there is 99% of salt and 1% of water. 100% means 0% of water so that would not be a salt water
Thanks. So this means that 50% that I cant dissolve any more salt?
Edited by QuantumBit
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
It depends on how much salt the water can hold given some conditions. Cold water for instance holds more oxygen than hot water. The term you're looking for is saturation.
But saying something like "100% salt water" means it's either 100% salt or 100% water. Or it's just salty water. It's very ambiguous.
Yep, this is also true.  I was thinking in terms of saturation levels and not percentage of parts per volume/mass.
I am not a Chemist but there would be a point where there would be too much salt and not enough water to dissolve it
Oh ok thanks
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
Ok I guess I'll stick with 50% then. Thanks!
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://www.reference.com/geography/maximum-solubility-salt-water-b5cba303939f22e#
The maximum solubility of table salt (sodium chloride) in water at 20 degrees Celsius is 35.7 grams per 100 milliliters of water. The solubility of most solids increases as the temperature rises and decreases as the temperature lowers.
50% would probably be too high since the amount of salt that can dissolve into water also depends on the temperature of the water.  The hotter the water the more salt that can dissolve into it and the solution is considered supersaturated.  At 20 degrees C, about 357 grams of salt can dissolve into 1 liter of water.
Thanks!
If you're in a chemistry class, titrate it with Silver Nitrate (AgNO3) and use Potassium Chromate as indicator (K2CrO4). The end point would be a faint orange cloudy solution. It is a double displacement reaction. The reasons why the 100% solution won't dissolve any salt anymore is because it's already saturated. However, even saturated solutions can dissolve more salt if it's subjected to external heat and frequent agitation.
There is more that meets the eye
I see the soul that is inside
The Dead Sea is probably very close to being saturated with salt if the water temperature was 20 degrees Celsius.  Having friends who have visited and swam in the Dead Sea, you can easily float in it and you will need a very very very thorough rinse off when you come out after a swim.  If you thought it was a pain to rinse yourself with fresh water after swimming in the ocean, it's several times worse with the Dead Sea.  Also, the Dead Sea is called the "Dead Sea" because the salinity is too high for any form of complex life besides bacteria and microorganisms.
Im sorry but how much would this be in percentages?
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
This is the answer you're looking for. It is also mostly correct.
NaCl however, is weird. It's solubility does not increase appreciably as you increase temperature.
I guess you can think of it as 35.7 parts of salt for 64.3 parts water.  But it would also be viewed as 100% of salt (as in all the salt you've poured into the solution) saturated into the water.
I guess you can think of it as 35.7 parts of salt for 64.3 parts water.  But it would also be viewed as 100% of salt saturated into the water.
Ok thanks. Just to make sure I could write 100% for the solution I'm using, 33.7% for the dead sea etc?
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
Ionic bond with a polar solution.
At maximum saturation it basicaly has the chlorine hanging off the bent hydrogen side, and sodium hanging off the oxygen side. after that point it ceases being a salt water solution, and becomes a saltwater suspension.give us a sec, and I'll run the math.
No, you can't.  With the Dead Sea, they are measuring in parts per unit volume/mass.  Your 100% in this statement is implying 100% of one element has dissolved into the solution without leaving any leftovers.  If you equate the two then your 100% has to imply that the solution is made up of 100% salt.
This statement would be true for the following conditions:
  1. Water temperature is 20 degrees Celsius
  2. Volume of water is 1 liter
  3. Mass of salt dissolved into the water is 357grams, and that no salt particle is left in the water undissolved
If the water temperature is higher or the water is more agitated, more salt will dissolve into the water before the solution becomes saturated.
