Hey LinusTechTips Community,
As the titles states, I have not had a PC for about a year outside of my laptop which is getting on a bit now. It is good when I want to play older games with its Intel-based graphics, but it is getting to that point now where I want to play a few more graphic intensive games. Part of me says just wait till CES and see what comes out and if I like it wait, but if not buy. I am interested in hearing your opinion on what I should do and I will also put a current PC Part List to compare if I should go ahead now or wait.
CPU: Intel Core i7 6800K
CPU Cooler: Corsair H115i
Motherboard: ASUS X99 Deluxe II
Memory: Corsair Vengeance LED 32GB (4x8GB)
SSD: Intel 750 1.2 TB PCI-E
Video Card: ASUS GeForce GTX 1070 8GB Dual
Case: Corsair 760T White
Power Supply: Corsair RM1000i
Update: I forgot to mention that a hobby of mine is Maya with modelling and animation so that is why I am going with a six core CPU instead of the 6700K and I am going to SLI/Crossfire next year hence the 1000W PSU.
I have no idea what I am doing
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/
What are you doing on this system? If you're only gaming, you could go for a Skylake rig which will perform better at a lower cost. Also, that power supply is absurdly overkill for a X99 + GTX 1070 rig.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995417
Swap the 6800K for a 6700K.
swap the 1070 for a 1080
get a RM750X for cheaper. you don't need 1000 Watts (not even close)
if you aren't gaming at 1440p or higher, you could get a 6600K + GTX 1070 and get a much cheaper system that is STILL overkill for 1080p
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995430
Yeah man...I'm not trying to be a jerk here...just curious what your game plan is???
You have been using Intel integrated graphics for gaming and your proposed build, for getting into graphically intensive games, is a super duper insane enthusiast grade PC as the solution.
Messing around aside. Is that crazy of a PC really what you want, or do you just want to get into gaming. If you really want that crazy of a PC...then just wait til CES...then you can choose from the latest greatest and truly enthusiast level products.
CPU: Ryzen 7 2700x cooled by Pure Rock Slim // RAM: Gskill Flare X 3200mhz CL14 2x16 32GB// GPU: Powercolor Red Devil RX 6650 XT 8GB// Motherboard: ASRock B450m Pro 4 // PSU: Seasonic G550 Gold 80+ // Storage: 4TB pcie nvme game drive, 512 GB m.2 sata3 OS Drive, 4 TB WD Red HDD // Monitor: Samsung S22D300 21.5" 1080p 60Hz, MSI 27" 1080p 144hz Freesync 1ms display // Peripherals:  Logitech fancy shmancy keyboard and moise with rgb and gaminess stuff, very fancy | Kingston HyperX Cloud Core headset
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995451
You don't need a 1.2TB SSD (especially not a 750 when there are 1TB ones for $280), or an X99 system, or 32GB RAM, or a 1000W PSU.
Instead I'd do:
i7-6700K
Asrock Fatal1ty Z170 Gaming K6
Corsair Vengeance LPX 16GB
Crucial MX300 1.1TB
EVGA GTX 1070 (any of them)
Case: Corsair 760t
PSU: Corsair RM750i
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995458
Nothing in the enthusiast space is going to change at CES. I could come back and bite my tongue. If your computer is your work machine, the extra 2 cores you get by going X99 is definitely worth it.
Desktop i7-5820K @ 4.7GHz | ASUS Rampage V Edition 10 | 64GB DDR4 Corsair LPX | Titan X (1st Gen) | 256GB 950 Pro SSD + 8TB WD Red HDD | Corsair AX860i | Lian-Li PC-O8 | macOS Sierra + Win10
Audio HD800 + Magni2/Modi2 | Keyboard WhiteFox/ErgoDox | Mouse G502 | HMD HTC Vive
Things I know about: Computer Building, Software Development, Headphones, Mechanical Keyboards, Cosplay, ?
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995509
35 minutes ago, Velvet Revolver said:
Looks good, you could wait until Zen comes out.
Yeah, that was my thinking and I do have a soft spot for AMD.
I tend to use the program Maya for modelling and animation for a hobby hence the X99 and I play Cities Skyline a lot which appears to actually use the additional cores. The overkill power supply is that I tend to go for SLI/Crossfire later down the track. Previously I have made a rig with an HD 7850 but then upgraded to Crossfire R9 290X etc. I plan to do the same here, just start out with the 1070 but then follow up with SLI or Crossfire whatever is better next year.
3
Thank you, but the reasons above answers these, but I appreciate the feedback.
Cheers mate, appreciate the feedback.
Instead I'd do:
i7-6700K
Crucial MX300 1.1TB
Case: Corsair 760t
PSU: Corsair RM750i
Cheers for the feedback, I'll see how much this will cost.
Haha, I'll hold you to it.
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995578
7 minutes ago, BenoitWW said:
umm. well lets say i would love to have your budget. this is a good content creation build. Gaming build would be 6700K + GTX1070/GTX1080
3
Cheers, I appreciate the feedback. I forget to mention that I like to use Maya for modelling and animation in the original post.
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995588
2 minutes ago, TrueZarken said:
Maya for modelling
Then to me, I think you prioritized the correct things (CPU, RAM Capacity). A without extra detail, people come here assuming that computer builds are solely for gaming.
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995600
Well he did say he was going to use this for gaming, and specified no other use, so at that time, it was pretty safe to assume that this was a gaming rig
Laptop:
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995610
Yeah, sorry about that, my fault for not fully explaining the use case of the PC. The originally post has been updated to accommodate for that.
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995616
no problem. in light of this newfound information, I think your build is awesome and well configured. you still don't need a 1000W PSU. Those components will take, maybe 500W at load. RM650X should be enough, but for an extra buffer, I would personally go for a 750W PSU in your case.
Laptop:
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995618
If you plan to Crossfire or SLI, just grab the Corsair RM750i instead. 1000W is still way more than you actually need.
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995628
I've observed that here, and on other sites that cater to build-it-yourself computers - pretty much almost all the ones i go on - people assuming build are for just gaming. :/
I'd like to be able to learn more about building PCs for more like office or home (non-gaming) use - for example, something for my parents, who keep computers a very long time, and who don't play games more intense than Solitaire (the one that used to come with Windows).
Just curious, how hard would it be to spec out a computer that excels in playing movies, doing office work, maybe some photo & video editing, etc, would be good enough overall to last at least 7-8 or 10+ years without having to upgrade any components other than adding storage (and still be as good then as an i7-920 with 16-24 GB RAM, a first-generation PCI-E ~200-300GB SSD & Windows 7 Pro is today), but can't even run any 3D games made after 1995 at all? (Or, maybe only gets 6-8 fps at lowest resolution & settings in the original Doom & Wolfenstein 3D?)  Or does the nature of graphics acceleration require using GPUs (even if just integrated graphics) that actually can run 3D games, to also play movies, do content creation, etc?
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995679
14 minutes ago, PianoPlayer88Key said:
- snip -
Honestly, not hard. We've hit a plateau where people are satisfied with what they already have. For casual use for years to come, a 4 core intel system with 16 GB of RAM and fast storage like an NVMe drive will last for a veeeery long time.
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8995735
Don't know a thing about the capabilities/needs of the Maya program but I have been away from PC gaming for a good while and some YouTube vids of Cities Skylines has reawakened my desire to build a gaming box. Cost is not a huge issue but I don't want to overspend needlessly. I have done a fair bit of research and found a benchmark that showed no particular advantage ( and actually fewer frames per second ) on a 6 core setup compared to a 4 core on CS. Not sure why. I think you and I might be looking for the same things in a new machine. I have chosen to wait to see what happens with the I7-7600 chip that will be coming out ( hopefully ) early January. Along with this is a new chipset. A few weeks ago it seemed that this might be a fairly big step up from the 6600K but more recent testing seems to negate the initial speculation. In any case I would consider waiting just a short time more. BTW if you know of any site that details and improvement in City Skylines with 6 cores please share them because I have only purchased a case and everything else is subject to change. Also, rather than a dual card video solution, I would consider a more powerful card ( or wait till Jan and buy a 1080TI )
Paul
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8997529
35 minutes ago, Melorski said:
Maya
3D modeling and animation program. It's who nvidia sells quadros to usually. Workstation apps get intense.
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8997668
This will get the job done at a MUCH better cost (that intel ssd is completely overpriced)
PCPartPicker part list: https://pcpartpicker.com/list/T9B2WX
Price breakdown by merchant: https://pcpartpicker.com/list/T9B2WX/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($329.44 @ OutletPC)
CPU Cooler: CRYORIG R1 Ultimate 76.0 CFM CPU Cooler  ($89.89 @ OutletPC)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($149.99 @ NCIX US)
Memory: G.Skill Ripjaws V Series 32GB (4 x 8GB) DDR4-3000 Memory  ($159.99 @ Newegg)
Storage: Samsung 960 PRO 512GB M.2-2280 Solid State Drive  ($329.00 @ B&H)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($89.99 @ B&H)
Video Card: NVIDIA Titan X (Pascal) 12GB Video Card  ($1200.00)
Case: Corsair Carbide 400C ATX Mid Tower Case  ($92.99 @ Best Buy)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ B&H)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($90.00 @ Amazon)
Total: $2631.28
Generated by PCPartPicker 2016-12-08 15:25 EST-0500
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
https://linustechtips.com/topic/703761-pc-less-for-over-a-year/#findComment-8998276
