I bought this psu intending on getting a gpu that used pcie power. i found a cheap gtx 670 but need two 6pin connectors. can i use adaptors with this psu to make it work or do i need to just upgrade? tried to stay in budget but i dont want my gpu to get fried or anything else in the pc for that matter.
https://linustechtips.com/topic/703348-enough-power/
I can feel your PC blowing up from england, I strongly suggest getting a better psu
6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
https://linustechtips.com/topic/703348-enough-power/#findComment-8989765
No, the power output on generic psu's is questionable at best, and those rating for the 12volt rail aren't high enough for a 670/cpu/motherboard/drives/fans etc all together.
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/703348-enough-power/#findComment-8989770
I have a older munchkin 800w psu. but i bought it 7 years ago wasnt sure if it was still up to the challenge lol. i dont want you to get hit in england
https://linustechtips.com/topic/703348-enough-power/#findComment-8989772
Its good, tell me when your going to turn it on and ill head to my bunker
PSU tier list-
https://linustechtips.com/topic/703348-enough-power/#findComment-8989773
https://m.newegg.com/Product/index?itemnumber=N82E16817812006
This is my older psu. its 7 years old granted it hasnt been in use for 5 years just sitting in storage.
https://linustechtips.com/topic/703348-enough-power/#findComment-8989779
it would be ok for now just make sure to give it a good dust off, PSU's don't like dust
PSU tier list-
https://linustechtips.com/topic/703348-enough-power/#findComment-8989783
For now as in a year? or like a month? i still have the reciept for the 400w and bought it less than 30 days ago. but if the 800w should last for more like a year ill see if my friend needs the 400w. closest microcenter center is 1.5 hrs away.
https://linustechtips.com/topic/703348-enough-power/#findComment-8989828
well as it is old it is hard to say if it will last and for how long but either way the 400w wouldn't be enough for your rig.
PSU tier list-
https://linustechtips.com/topic/703348-enough-power/#findComment-8989832
True. well thanks for all the help. you can rest easy knowing the 400w isnt going into the system with that gpu.
https://linustechtips.com/topic/703348-enough-power/#findComment-8989842
