Replacement mouse for razer naga?
tobben
Hi folks, my stoneage razer naga is finally
dying on me. Figured i would try to buy a
replacement today, my budget is probably
around 30-60$.
The razer naga is abit small, i probably have
medium sized hands, so i'm looking for
something abit bigger. Hopefully a few macro
buttons(not as many as the naga), and the
buttons on the left mouse would be great to
have if possible.
Picture to clarify.
Any recommendations? Not sure if i care about
mechanical keys and such on a mouse, as long
as they last a long time.
Not sure i have a weight preference, but i think
medium as opposed to super light might be
preferable. I dabble in fps but they aren't the
main games i play.
As someone that used an old Naga and got the current one this year I'd say Razer is making larger Naga's than they used to. But unless you are playing MMO's the Naga is not really designed for you and the Naga Hex is made for Moba's. They are very specific use cases.
OBSIDIAN: CPU AMD Ryzen 9 3900X | MB ASUS ROG Crosshair VIII Hero Wifi | RAM Corsair Dominator RGB 32gb 3600 | GPU ASUS ROG Strix RTX 2080 Ti OC |
Cooler Corsair Hydro X | Storage Samsung 970 Evo 1tb | Samsung 860 QVO 2tb x2 | Seagate Barracuda 4tb x2 | Case Cosair Obsidian 500D RGB SE |
PSU Corsair HX750 | Cablemod Cables | Monitor Asus PG35VQAsus PG279Q | HID Corsair K70 Rapidfire RGB low profile | Corsair Dark Core Pro RGB SE | Xbox One Elite Controller Series 2
@DELTAprime I play mmo, moba, fps, rpg,
you name it :P.
About the naga being bigger, no kidding..
I was at the store and tried it out, my naga
is so small i got to curl my fingers to use it.
The current naga is so big i can't even use
the 12 buttons properly with my thumb, it's
just too big, much bigger and wider than my
old one, huge in comparison.
With too little thought i ordered a naga hex,
hopefully it will fit my hands and have decent
buttons.. It will arrive in 1-2 days, fingers
crossed. Far more expensive than i thought it
would be, 107 bucks, insane.
This one, don't like the design or shape now
that i look at it again, oh well.
https://www.expert.no/data/tastatur-og-mus/mus/razer-naga-hex-moba-action-rp/p-221891/
4 hours ago, tobben said:
(I am not really going by your budget, Ill try but its hard cause ill be going through the barebones)
Would you be okay with just a bunch of macros around the mouse instead of a numpad on the thumb cause the only direct alternative to this is corsair scimitar, also being 119mm so pretty much the same size as the naga.
The scimitar having the better sensor, 3988 over the 2034 on the Naga
For reference the Deathadder Chroma, a very good mouse and great sensor, the 3989 comparable to the 3988.
Overall the Scimitar is pretty much the better naga if you are looking for a direct alternative
As for other alternatives I say G502 or G900 for the oh so famous 3366 fan favorite sensor. Both having a great feel Solid build and great MCU as well which is a plus for the software customization.
I think i prefer the thumb, want to move the
mouse accurately while using the buttons.
I can't imagine being able to use any of the
mice with awkward buttons everywhere :P
It looks like i am gambling with the razer
naga hex, even if it doesn't seem all that
appealing, and i didn't even get to try it at
the store. Hopefully it will work out. Thanks
for the input @Aytex.
I very much considered the deathadder
chroma, seemed like a nice fit and not too
expensive, but i didn't want to be stuck with
two buttons.
Going to miss those two buttons on the left
mouse button though, so great when you
are just browsing.
The Steelseries Rival 500 is a fairly new mouse and seems to cover your needs. It has more buttons than the Naga Hex, a waaaay better sensor and the best thing is - it's not a calculator mouse, so there's a somewhat proper thumb rest.
From salty to bath salty in 2.9 seconds
That looks interesting actually, would like
to give it a try. Does the hex have a shitty
sensor? i hope not, because it's horrifyingly
expensive.
expensive.
Both the old and the new one (the V2) have some form of a Philips Twin Eye laser sensor (rebranded under a different name by Razer). It has a Z-axis tracking issue, which results in an unwanted behaviour when lifting the mouse. The Rival 500 has the best optical sensor currently available - the PWM3360. I seriously feel like Razer uses these laser sensors only to boast high DPI numbers on the box.
@Pandalf Pretty sure my naga does the
same thing. Annoying but not deal breaking,
granted it doesn't seep into other things.
I have the sensitivity on max, so it's hard to
tell.
same thing.
The original Naga and the Hex have the same sensor. If you didn't find it a problem, then it's okay, but I'd still suggest getting something with an optical sensor instead.
Agreed the pln  sensors were not a good choice
I ended up with a razer chroma deathadder..
I waited 3 days and apparently they didn't have
the hex after all.
If i knew it would turn out like this, i would just
have taken my time and ordered a proper
mouse online.
What's done is done, it sits nicely in my hand,
seems like a decent mouse, just not nearly
enough buttons for my playstyle.. my pinky
and ring finger are also scraping on the
mouse pad.
the hex after all.
mouse online.
mouse pad.
How come you didn't go for Elite? Iirc it has a new sensor and the build quality should be a bit better.
The ability to google properly is a skill of its own.
Didn't have it in store, also currently a fair
bit more expensive than the deathadder,
atleast here. On par with the naga and hex.
Oh right, Norway. I just assume everyone here is from US or Canada and it's $66 on Amazon. ^_^
