External USB Drive question?
There are loads and loads of different options. Just Google "external hard drive enclosure".
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
1 hour ago, RKRiley said:
yes you can buy sata to usb cables.
ignore the enclosure suggestions, those are for hdds and ssds so wont work for this :P
1 hour ago, doomsriker said:
1 hour ago, M.Yurizaki said:
Yes, there are various HDD to USB adapters, normally in the form of hard drive external enclosures.
 ROFL I meant disc reader like this one http://www.newegg.com/Product/Product.aspx?Item=N82E16827135304 my bad for saying drive
If it's a SATA drive, you can still use some kind of SATA to USB converter.
4 hours ago, doomsriker said:
So there's no way to rig one made to put in a desktop to use like the one I linked you to?  I rlly don't wanna buy a new one
22 minutes ago, lilbman said:
-facepalm-boyuo.jpgIs there any way I can connect one of these to my laptop??
https://www.amazon.com/Vantec-CB-ISATAU2-Supports-2-5-Inch-5-25-Inch/dp/B000J01I1G
i.e. This is a IDE or SATA to USB adapter. It will convert the interface of the 5.25" DVD drive into a USB port that you can plug into your laptop or whatever else you want to use. I included an adapter that does both because hell if I know what kind of drive you have other than it's an optical drive.
If this is not what you're looking for then you are not clearly explaining what you want.
I don't think I could use my old one because it has two cables-one is a SATA cable, which the adapter works with, but one goes into the motherboard.  I don't know where the cable that goes into the mobo would go.  I assume it's for powering it, but I could be wrong.
 Would I be able to do this with the cable you linked me to?
