gtx 1060 not performing fully!
vXeno
Hi there!
I did the plain firestrike benchmark and i only scored 7500 compared to most 1060/i5 6500 rigs getting 10k, also when i play gta i experience major lag spikes! I was maybe thinking my 2.5" hdd was slowing it down?
Thanks
Specs-
i5-6500
Gigabyte windforce oc gtx 1060
2x 4gb kingston hyperxfury 2133 in dual channel
Asrock h170 fatal1ty performance
bequiet pure power 9 500w cm
1000gb hdd-ST1000LM024 HN-M101MBB
you bought a 3gb version? it is slower than a 6gb if you did.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
Can you post a picture of your settings in GTAV?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Also, is it a 3GB or 6GB 1060?
1 minute ago, vXeno said:
Its a 1060 6gb, the settings are much below the nvidia recommended1`11`.PNG 122.PNGCapture.PNGwe.PNG
why is it direct x11?
Temps? Load?
It doesn't matter
People scores in Firestrike are with overclocked GPU to 2100+- Mhz. You have to scroll down to position 300+ to find 1900+- Mhz results.
I bought my 1060 last week as well.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
Just now, Thony said:
People scores in Firestrike are overclocker to 2100+- Ghz. You have to scroll down to position 300+ to find 1900+- Mhz results.
Have you played gta v?
No, deleted the game long time ago. I have 144Hz monitor now and cant play at 60fps.
6 minutes ago, deXxterlab97 said:
Temps? Load?
It doesn't matter
75-95% load 65-71*C
O
Oh cool
how many frames are you getting exactly?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
Normally about 75 with v-sync then it Spikes down and up
try turning off v-sync.
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
16 minutes ago, vXeno said:
Here's a video of my gta benchmark @Oswin
It looks like v-sync is messing up.
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
Disable Vsync in Nvidia Control panel too because I just checked my FireStrike (free demo) score and I got 10749. Your 7500 sounds like you have that 3GB version or your card is severly bottlenecked by something in your PC or your software.
You should monitor your cards performance with MSI Afterburne or GPU-Z to see if there are any thermal issues or if your card is even under decent load.
Hey guys, i turned v-sync off in nvidia control panel and i got a score of 10862 in firestrike demo, thanks for the help!
