It's normal for the CPU to lower core frequency if that core doesn't have a lot of work to do.
x4 860k is stock 3.7 ghz and goes turbo up to 4 ghz. I think 3.925 Ghz or something like that is an in-between step between stock and maximum boost.
If a core isn't used much, it lowers its frequency to 2.5 ghz or 1.7 ghz or maybe even lower.  As it produces less heat, this means other cores can boost temporarily to higher frequencies and use more power and produce more heat, without producing overall much more heat. That's how some cores can be boosted up to 4 Ghz.
[REDACTED]
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
3 minutes ago, wrathoftheturkey said:
I was quoting him because it wasn't relevant to the original post, it was only relevant to the next post he made. Don't quote the original post, but if the answer is directly addressing something else said in the post then it makes sense to quote.
Oh, he didn't add the quote to the 2nd post? Never mind then. Carry on.
Go to Power Options and select High Performance if you want a your clock speed from BIOS without jumping. I would recommend "balanced mode", so when the CPU is doing nothing at idle, it will down clock itself to your CPUs stock clock, and when you put some preasure to it, it will boost up to whatever you overclocked it to in the bios.
Put high performance if you don't want clock speed to jump
Main:  1650 v2   @ 4,6GHz   -   X79 Deluxe                -   GTX 1080 @ 2000MHz   -   24GB DDR3 @ 2400MHz / CL10
Side:   i7-4790K @ 4,5GHz   -   Maximus 7 Hero        -   GTX 1070 @ 2114MHz    -  16GB DDR3 @ 2666MHz / CL12
HWBOT
