I updated my bios and believe that I have a corrupt install, would like to verify and have any recommendations for fixing this issue. The reason for my bios update was because my computer would not boot properly after installing the new graphics card.. I believe I have dug myself a deeper hole that what I was already in.
System specs:
Intel 2500k
MSI z68A-g45 g3
8gb of kingston ram
xfx hd6850 going to evga gtx1060
The issue im currently experiencing is that the computer will turn on for 10 seconds approximately, and then it will restart and loop.
I have tried pulling the cmos battery, and unplugging the power supply. To try and reset
Have tried pulling one ram stick at a time, still doesn't work
EDIT: I have already pulled out the dedicated GPU and am running off of the onboard
https://linustechtips.com/topic/701201-computer-will-not-post/
try the onboard gpu.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/701201-computer-will-not-post/#findComment-8965372
System specs:
Intel 2500k
MSI z68A-g45 g3
8gb of kingston ram
My question is have you use the CMOS jumper?
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/701201-computer-will-not-post/#findComment-8965398
I have shorted the two connectors for the CMOS jumper while the computer is turned off. since there was no bridge on the two pins to begin with, I would have to short it to reset the cmos correct?
https://linustechtips.com/topic/701201-computer-will-not-post/#findComment-8965412
All you do is put the jumper on the board WITH the power supply turned off.  Otherwise it will just stay charged via the power supply.  Additionally, to me it doesn't sound like a firmware issue, if the firmware wasn't working it would simply just stay on forever and not get anywhere...  I think its power delivery related.
https://linustechtips.com/topic/701201-computer-will-not-post/#findComment-8965418
so you suggest that I should try using a different powersupply? since i did the cmos jump correctly?
https://linustechtips.com/topic/701201-computer-will-not-post/#findComment-8965421
To me, it sounds like its power delivery.  I think that once the system finishes POST and then it goes under load, it will droop causing a power adjustment, maybe even outside of the tolerance...  Thus, you've got a computer turning off without warning.
Let me ask you this, do you have to flip the power switch on the power supply before it will turn on again?
https://linustechtips.com/topic/701201-computer-will-not-post/#findComment-8965436
I can turn off the computer when its in the loop by holding the power button (on the case), and no I also use the power button on the case to turn it on.
https://linustechtips.com/topic/701201-computer-will-not-post/#findComment-8965445
Are you able to get to the BIOS at all?
https://linustechtips.com/topic/701201-computer-will-not-post/#findComment-8965448
nope.. not at all :(
And you're saying now that you'll turn your computer on and it will just hang, not turn off on its own?
https://linustechtips.com/topic/701201-computer-will-not-post/#findComment-8965478
it will turn on and then display a black screen for about 10 seconds (my fan leds are on) and then it will restart on its own, and repeat
https://linustechtips.com/topic/701201-computer-will-not-post/#findComment-8965488
