Choice
4 members have voted
  1. 1. Which one for Games, Movies, Music
    • Harman Kardon Soundsticks III
      1
    • Swan M10
    • Logitech Z623
      3
Hi all, I'm looking for a 2.1 speaker system for all around use on PC. I'd like the bass to shake a small room just a little (so that there is presence).
The ones available are the Swan M10, Soundsticks III and Logitech Z623. Price range is less than $200.
I'd like to have good sound quality and from searches, the Swans are great but lack bass. It seems as if it is as follows:
Quality: Swans
Bassy: Logitech
All Rounder: Harman
Need some advice please.
Thanks in advance.
https://linustechtips.com/topic/701099-which-21-speaker-system/
Just got the Z623, Awesome, loud, and can pump out some hefty bass. I would recommend it, but I can't compare to the others because idk anything about them.
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
https://linustechtips.com/topic/701099-which-21-speaker-system/#findComment-8964266
Thanks for the fadt responses. The reviews I read about the Swan and Harmans stated that Logitech is bad sound quality. Interesting that Logitech seems more loveable here hahaha.
Is there a difference between a desk sub compared to a forward blasting one put on the ground or one that shoots downwards?
https://linustechtips.com/topic/701099-which-21-speaker-system/#findComment-8964295
Not the Logitech.
I would go Harmon kardon
Logitech is bad
https://linustechtips.com/topic/701099-which-21-speaker-system/#findComment-8964318
10 minutes ago, Jack Russel said:
Hi, is there a reason? I often hear this when reading other forums but no explanation is given usually.
Logitech just has generally bad sound quality
https://linustechtips.com/topic/701099-which-21-speaker-system/#findComment-8964446
Aaah, so I assume the Logitech has the bass but the other sounds like get ruined more than Harmans?
I have heard that Swan has great quality but the sub on it is a small desk one and that I find concerning.
https://linustechtips.com/topic/701099-which-21-speaker-system/#findComment-8964464
