hi guys,
im in the middle of my first build right now, and I'm struggling.
i put on slightly too much thermal paste, and it started squeezing off the edge. Not sure if it was supposed to, but I ended up wiping off the edges with my sleeve.... Now I'm not sure if there's too little.... but that's not my real issue lol.
My Cooler Master EVO 212 is screwed in as tight as I can tighten it, but when I stand my case up, it hangs down a bit, so it's not completely touching my CPU.
Using an Asus aa - 2 2011-13 motherboard btw
im so nervous I'm going to damage something in the middle of all this mayhem. Hoping someone can help me get this thing installed properly.
any words of wisdom are very appreciated.
thank you
https://linustechtips.com/topic/701048-evo-212-2011-3-issues/
Picture?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/701048-evo-212-2011-3-issues/#findComment-8963657
Looks like you placed the brackets upside-down.
https://linustechtips.com/topic/701048-evo-212-2011-3-issues/#findComment-8963720
The bracket that is screwed in?
I would have to flip the screws around to install it in reverse, and it came with the screws in place.
Or are you talking about something else?
https://linustechtips.com/topic/701048-evo-212-2011-3-issues/#findComment-8963728
https://linustechtips.com/topic/701048-evo-212-2011-3-issues/#findComment-8963768
11 minutes ago, ARikozuM said:
Ok, just gave it a second go and I think my issue was that it wasn't locked into that little sub where the bracket meets the plate.
Should I be worried about the thinning of my thermal paste?
https://linustechtips.com/topic/701048-evo-212-2011-3-issues/#findComment-8963829
There should be enough. Do you still have some paste left over?
https://linustechtips.com/topic/701048-evo-212-2011-3-issues/#findComment-8963873
Nope, found the real issue.
I'm using the big standoffs as opposed to the small ones!
So it's too far away from the CPU
I hope this works
https://linustechtips.com/topic/701048-evo-212-2011-3-issues/#findComment-8963918
I hope this works
Should have gone with Deepcool 400. xD
https://linustechtips.com/topic/701048-evo-212-2011-3-issues/#findComment-8963936
lol I'm new to this, I wen't off of good video reviews and a couple recommendations.
I really wish I woulda gotten a cooler with thermal paste pre-applied. This stuff weirds me out
https://linustechtips.com/topic/701048-evo-212-2011-3-issues/#findComment-8963947
