How to change fan curve on reference RX 480?
nkucz
Hey guys,
Wondering how to make a custom fan curve on the reference RX 480? Also I want to crank the fans so I get really low temperatures considering I don't care about noise, so what should I set the fans at? Any help would be greatly appreciated.
Thanks!
Intel i5 3570K || Gigabyte GeForce GTX 1070 8GB FE || 8GB Crucial Ballistix Sport 1600MHz || ASRock Z77 Pro 3 || WD Caviar Blue 1TB || Noctua NH-U12S || Creative Sound Blaster Audigy FX Sound Card || Fractal Define R4 || Gigabyte GC-WB867D-I REV 4.2 Wireless Network Card
ASUS VC239H Monitor || Corsair Strafe Cherry MX Red || Logitech G Pro || Philips SHP9500 w/ V-MODA BoomPro Mic || Reflex Lab Pro 36 Heavy Mouse Pad || Google Nexus 6P 128GB
13 minutes ago, nkucz said:
Hey guys,
Thanks!
Get MSI Afterburner. You can do whatever you want for fan curve. I have minimum 25%fan speed at all times, and 100 fan speed by 60 degrees.
Wow....that should be loud. I actually kinda like the temp target that is implemented by amd. But I guess that is preference
PC: AMD Ryzen 5 3600 @4.2HGhz 1.25V || Noctua NH-U12S SE2 || 16GB (2×8GB) Aegis 3000Mhz CL16 @3200Mhz ||
|| Sapphire Pulse RX 6700 10G || MSI B450i Gaming PLUS MAX Wifi
  || Kingston NV1 2TB m.2 ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
It really isn't too loud. I have MSI R9 380 with Twin Frozr, so its fairly quiet. Plus, it never gets up to 60 degrees. The curve pretty much keeps things down early. It'll get a little loud as it approachesfull speed, but the fans on my H100i get a little louder than my GPU fans. By the time things get that loud I'm pretty into my game, so I never notice the sound.
