6700k cooler for less than $100?
Solved by Energycore,
17 minutes ago, xYowie said:I want to oc to 1.4v, I don't care if its air or water as long as it fits in my case, i have a z170-a motherboard with corsair dominator platinum which is pretty tall, i currently have a hyper evo 212 and it barely fits in the first slot closest to my cpu. Most good air coolers are bigger than the evo so i don't want to buy something doesn't fit, Any recommendations?
Noctua NH-D15S (not the NH-D15).
Should have no problem with Dominator Platinums.
8 minutes ago, arnavvr said:Noctua NH-D15/Cryorig R1 Ultimate/Silver Arrow Extreme
You didn't read the part about Dominator Platinum did ya
