What up,
how many extra fps can I expect when buying another Geforce GTX 970 Zotac AMP Extreme Edition? It is way cheaper than buying a 1070 instead the 970 but how much more performance will it give? Will it be close to a 1070 performance?
PS: I have an i7 4790k, 16gb RAM
https://linustechtips.com/topic/700045-970-sli-fps-boost/
It depends on the game, but the highest you will likely see is ~80% additional performance.
https://linustechtips.com/topic/700045-970-sli-fps-boost/#findComment-8952620
970 sli is generally a fraction above that of a 980ti, but less than a 1070 in the games that SUPPORT SLI. I just dropped 970 SLI for my 1080, however I had a very good experience in that 18 months, only Just Cause 3 caused me issues.
However and a big HOWEVER - 3.5gb/4gb vram (depends what camp you're in) is quickly becoming the normal amount for a game to use at 1080P and SLI doesn't offer anymore VRAM due to the way it works. If I was you (keep in mind what I did) I would sell the 970 whilst their prices are decent and grab a 1070. That card will last you longer due to the 8gb vram and will offer you the option of 1070 sli later
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/700045-970-sli-fps-boost/#findComment-8952631
2 minutes ago, momsspaghetti said:
Well that does not tell me anything. Do you know anything certain for a specific kind of game?
Well, what games do you plan on playing?
https://linustechtips.com/topic/700045-970-sli-fps-boost/#findComment-8952637
I might do that in June next year (I am currently not at home). Thanks buddy
https://linustechtips.com/topic/700045-970-sli-fps-boost/#findComment-8952649
Very Much Depends on the Resolution. At 4K 970 SLI gets hampered by It's low VRAM and the 980Ti and 1070 beat it.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/700045-970-sli-fps-boost/#findComment-8952694
