Lamptrons and Bitfenix recons are good products.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
I'm using the NZXT Sentry Mix 2 and it works perfectly, my fans are running more quiet than they were previously plugged straight into my motherboard and the Sentry 2 looks great :)
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
CPU: FX 8350 MOBO: MSI 970A-G46 RAM: 8 GB Corsair Vengeance 1600 GPU: EVGA 560ti SLI Case: Corsair 300R Cooler: Corsair H60 - push pull CM Excaliber SSD: OCZ Vertex 3 120GB HDD: 1TB Hitachi, 4TB Seagate PSU: Corsair TX650V2
Budget? How many fans are you going to run? Any preference on aesthetics? I'd personally go with Lamptron.
https://linustechtips.com/main/topic/65954-lamptron-fc5-v2-unboxing-and-overview/
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
I have it too but my only complaint is when you turn your computer from sleep it lights up again. If you have your case twisted away from you its sort of inconvenient
My computer is either on or off, no in between so I've never had that problem :P
