i5-6400 wont overclock again
Solved by lilywhiteffs,
37 minutes ago, SkilledRebuilds said:If it was me..and experienced this...I would check/memorize the bios then revert your bios to "default" with a hotkey (check manual or bios) and then go through it settings it up accordingly again and check results.
If not already done.
turns out after changing my fclk to 400mhz and v to 1.36 it worked
Featured Topics
VinSen ·
1
Fahizzle ·
6
INotPablo ·
Posted in CPUs, Motherboards, and Memory1 -
nugget1414 ·
Posted in General Discussion0 -
2
KN923 ·
Posted in Troubleshooting1
