Hello LTT,
I am buying my first true gaming computer in about five months. My budget is $1,200 without the processor, as I will be using the i7-4790K which I am currently using on my psuedo-gaming computer. My question is: should I dish out the extra $150 for a 1080 over a 1070? I play a mix of low FPS games like Minecraft and high FPS/graphics games like Overwatch and Rocket League, if that gives you guys a better idea. I also record and stream, if that matters. Please ask me if you need any other information.
-Jack
https://linustechtips.com/topic/699321-my-first-graphics-card/
2 minutes ago, PB3 said:
Hello LTT,
-Jack
what resolution?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/699321-my-first-graphics-card/#findComment-8944321
5 minutes ago, PB3 said:
Hello LTT,
-Jack
Those games are all fairly easy to play, I wouldn't waste the money unless you plan on playing other new AAA titles soon or want really good future proofing
Was I helpful? Accept my answer or agree / mark me as informative!
Quote me, or I probably won't notice you responded to me!
Only Constructive Criticism is taken into consideration.
https://linustechtips.com/topic/699321-my-first-graphics-card/#findComment-8944336
