What products are cheap, but really good for cable management. I was looking at the cable raceway, Velcro ties, and possibly cable sleeves. I was wondering what combination of cable management products are the best and are cheap for all under $30. I already have cable clip holders from mudder. They are ok for charging cords but that's it. I would like the total price to be under $30. A few dollars above is ok.
https://linustechtips.com/topic/699228-cable-management/
Zip-ties. 10/10, easily cable management tool.
https://linustechtips.com/topic/699228-cable-management/#findComment-8943167
if it needs to be re-usable velcro is the way to go, zip ties are pretty bae as well, but i'm an idiot and i just collect the twisty-ties from products i buy, and use those :D
and if you're in the market for whole desk cable management, that market is so stale and filled with crap i solved it with a chinese 3D printer:
EDIT: better picture is better.
https://linustechtips.com/topic/699228-cable-management/#findComment-8943183
