"Disable" monitor without unplugging?
By
OLS
in Graphics Cards
in Graphics Cards
Solved by Tosa,
Yes.
Assuming you use Windows 10, you can right click your desktop, enter Display settings, highlight the monitor you want to disable and select "disconnect this display" under the "Multiple displays" drop down box.
Featured Topics
eric_s ·
Posted in Power Supplies7 -
1
Silencix ·
Posted in Cases and Mods1 -
7
LambdaBird ·
Posted in General Discussion6 -
2
12
4
