H440 air pressure
Froody129
Hey guys
i was wondering if the H440 V2 in its stock configuration with the PSU facing down has positive or negative air pressure. Any help would be appreciated.
That's an F in the profile pic
utilizing a newer PSU (fan does not turn on till a certain load/temp) prolly a zero effect.
remember the three intake fans are filtered. this reduces the overall air intake volume (45-55%).
so that'd be 3x 45cfm intake (adjusted for air filter would be 67.5cfm) 1x 50cfm exhaust. for a net slight positive pressure at 100% fan speed.
fan facing upward would be like adding another exhaust fan into the equation would make it a negative pressure. since the fan is down, then it'd have no effect on the case internals.
Ok thanks. I also read some things about the fan hub not supporting speed change. I'm going for a quiet build and fans at 100% would be annoying. Can the stock fans at least change speed on the stock fan hub?
as like the 3-pin fans with a voltage change, but for a best PWM solution, using the motherboard and fan splitters works very well:
41IYzVT1j2L._SY355_.jpgpwm_cooling_fan_splitter_black_sleeved_d
