Im building a PC intended to be used for games and work when starting Uni. Is this build ok for 1080p gaming and is there any way i can cut the price down a little?
https://nz.pcpartpicker.com/list/T3wsnn
R5 5600   Asus ROG Strix RTX2060   B550  Crucial Ballistix 16GB DDR4   Kingston A2000 1TB M.2    Kingston UV400 SSD   NZXT H510 Flow
https://linustechtips.com/topic/697064-pc-money-saving-advice/
cheaper ram
RyzenAir : AMD R5 3600 | AsRock AB350M Pro4 | 32gb Aegis DDR4 3000 | GTX 1070 FE | Fractal Design Node 804
RyzenITX : Ryzen 7 1700 | GA-AB350N-Gaming WIFI | 16gb DDR4 2666 | GTX 1060 | Cougar QBX
PSU Tier list
https://linustechtips.com/topic/697064-pc-money-saving-advice/#findComment-8923007
If you don't absolutely need brand new, look at used.  A lot of sellers on eBay have return policies if parts don't work, and if it's on Craigslist, you might have a chance to test the product before buying it.
The Full Pounder Korbger (main PC):
CPU: AMD Ryzen 5 7600X | CPU Cooler: Deepcool AK500 ZERO DARK | MOBO: Gigabyte B650M AORUS ELITE AX | RAM: G.Skill Flare X5 32GB DDR5-5600 | Storage: Kingston NV2 1TB NVMe SSD, 2x Inland Professional 1TB SATA SSDs | GPU: ASRock Challenger Radeon RX 9070 | Case: Fractal Design North | PSU: Montech CENTURY II 850W 80+ Gold
Sheer Will and Spite (home server):
CPU: AMD A10-7870K | CPU Cooler: Stock AMD Cooler | MOBO: ASRock FM2A88X PRO3+ | RAM: Crucial 16GB DDR3-1600 | Storage: Kingston SSDNow S50 16GB SSD, Crucial MX100 512GB SSD, Seagate BarraCuda 2TB HDD, Western Digital Blue 2TB HDD, Seagate BarraCuda 1TB HDD, Seagate 1TB hybrid drive | GPU: Sparkle ECO Arc A310 | Case: Apevia X-Plorer | PSU: Thermaltake Smart Pro RGB 750W 80+ Bronze | Expansion Card: VOGZONE 2.5Gb PCIe Network Card
The Curb Stomp Coin-Op (MAME Machine):
CPU: AMD Ryzen 5 1600 | CPU Cooler: AMD Wraith SPIRE | MOBO: Gigabyte GA-AB350N-Gaming WIFI | RAM: Patriot Signature Premium 16GB DDR4-2666 | Storage: PNY CS900 240GB SSD, Samsung 860 Evo 2TB SSD | GPU: Gigabyte GeForce GTX 1050 Ti | Case: Homemade Arcade Cabinet | PSU: Corsair RM750x 750W 80+ Gold | Monitor: ONN 21.5" 1080p 100Hz Freesync
Bazzite Box (HTPC):
CPU: AMD Ryzen 5 3600X | CPU Cooler: Wraith Spire | MOBO: ASRock AB350 Gaming-ITX/ac | RAM: Corsair Vengeance RGB 16GB DDR4-3000 | Storage: WD Black SN770 1TB NVMe SSD | GPU: PowerColor Fighter Radeon RX 6600 XT | Case: PowerTrain X-GAMER X100 | PSU: MSI MAG A650BN 650W 80+ Bronze
https://linustechtips.com/topic/697064-pc-money-saving-advice/#findComment-8923016
It's definitely ok for 1080p, if money is tight you can definitely shave the price down here and there:
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($266.31 @ PC Force)
Motherboard: Asus H170-PRO ATX LGA1151 Motherboard  ($173.63 @ PC Force)
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory  ($67.50 @ 1stWave Technologies)
Storage: Kingston SSDNow UV400 120GB 2.5" Solid State Drive  ($65.00 @ 1stWave Technologies)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($76.63 @ PC Force)
Video Card: Gigabyte Radeon RX 480 8GB G1 Gaming Video Card  ($436.50)
Case: Cooler Master N300 ATX Mid Tower Case  ($78.99 @ PB Technologies)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply
Total: $1164.56
Generated by PCPartPicker 2016-11-26 13:24 NZDT+1300
sudo chmod -R 000 /*
https://linustechtips.com/topic/697064-pc-money-saving-advice/#findComment-8923031
1 minute ago, deXxterlab97 said:
no. because you also have to pay extra money for a motherboard and most game won't be needing that unless you are doing something extremely cpu intensive
the motherboard is only $20 more than the h170 version and cpu is about $40 more
https://linustechtips.com/topic/697064-pc-money-saving-advice/#findComment-8923085
7 minutes ago, Tweakforce_LG said:
what would be better for retaining resale value?
a Macbook :D
Seriously tho Custom PC's use a lot of value, and you probably have to sell the parts seperatly. Another thing for me, was that i couldnt be efficient at the pc i gamed on, but YMMV.
It would also be interesting what you study and what games you plan to play with it.  btw at university i hardly ever had time to play games
https://linustechtips.com/topic/697064-pc-money-saving-advice/#findComment-8923122
the 4gb 480 is $80 cheaper witch isnt a big deal here, but for 1080p, would the 8gb be too much vram?
https://linustechtips.com/topic/697064-pc-money-saving-advice/#findComment-8924099
quote us if you want us to see your questions, otherwise we don't get a notification.
8gb are definitely not necessary for 1080p, but there's more to it than that. An rx 480 is faster than a 470 regardless of whether you use the extra vram or not. You can scale it down, but you won't get similar performance. An rx 470 is fine, but I'd keep the 480 if you have the money.
https://linustechtips.com/topic/697064-pc-money-saving-advice/#findComment-8924844
I got the 8gb already purchased. In the end i dropped the 6600k for a 6500 and the z170 for a ASUS H170M-Plus. It has a usb-c (usless) but also an m.2 slot if i need it in future. The 8gb card will help if i decide to get a 1440p monitor. Total cost in the end was $1291.05 NZD ($909.40 USD)
https://linustechtips.com/topic/697064-pc-money-saving-advice/#findComment-8927956
