Hi,
I have the G.Skill ripjaws series 4 ddr4 Ram and was wondering if i bought the Series 5 if they would work together without any problems. I ask because series 5 is currently on sale waaay cheaper than the series 4. I assume the would work because the CAS Latency, timing and voltage are the same but just at the series 4 speed. I just wanted to make sure with before i buy and install. thanks =D
https://linustechtips.com/topic/696528-will-these-two-memory-models-work-together/
memory is basically all the same
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Probably, they should run automaticly on a speed of 2133mhz ( the lower one of these kits) but sometimes they don't do that automatic than you may have to configure the settings in your BIOS manualy, than it's more likly that they will work together.
But overall you can only test it, they should work but if not just send them back and order a diffrent pair of RAM sticks.
Basicly any DDR4 stick should work in your motherboard and at least if you set them to the same timings, voltage and speed (most of thetime the motherboard do exactly that by itself)
Yes it will work, but they will be all running at 2133MHz, unless you can OC old ones to 2400MHz.
It's possible ... same was with HyperX RAM that I bought. It went from 1866MHz to 2133MHz without any problem.
And people were buying 1600MHz, and changing it to 2133MHz.
Anyway difference between 2133 and 2400MHz ... won't be that big.
It will work!
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
